Removing wheel hub on JD 155C
   / Removing wheel hub on JD 155C #1
PArnold993
Grass Valley CA
JD 155C
I need to remove a front wheel for a tire repair. The cap protecting the hub is a flexible plastic, and should come off easily, but not for me. I have tried with hands, with channel lock pliers, and small pry bar. Nothing works. Can somebody give me the secret?
   / Removing wheel hub on JD 155C #2
I use a lady slipper to get behind it and work plastic over the washer. Worse case cut it off with a utility knife. Caps are about seven bucks. Good luck.
Ford F-450 Utility Truck (A55218)
Ford F-450 Utility...
Toro Mower (A50324)
Toro Mower (A50324)
1994 International 3800 Bus (A54814)
1994 International...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
1995 PETERBILT 377 TRI  AXLE DUMP TRUCK (A54607)
1995 PETERBILT 377...
2015 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2015 Chevrolet...
