removing the PTO cover
   / removing the PTO cover #1
jimg
Hi,
After mowing season was done I removed the PTO from the mower w/ an eye to clean and lube it. I got to that a few wks ago and am completely mystified on how to remove the PTO cover. I'd really like to clean the greasy gunk from the shaft but until I can get the cover off thats not possible. Now I know it had to be off in order to size the cover and shaft to my tractor. There must be a way to disengage the tab that connects the cover and shaft. (The tab runs in a groove in the shaft.) I fiddled w/ it a good long time though and couldnt figure it out. The shaft did come w/ a booklet and it shows how to remove the cover on all models exc. the one I have. Its Italian made and came w/ a LP finish mower. Any ideas?
   / removing the PTO cover #2
MIne had three wire tabs that you had to push in all at once. I basically pushed one in at a time while pulling on the cover. That would hold the tab in while I did the other two. It came off with no problems at that point. Another one I had on the brush hog was three pins that you actually turned and pulled out. Hope this helps you.
murph
   / removing the PTO cover #3
Wish we had a good picture of it, Jim. I've seen at least 3 different designs, but like you said, it's made to come off; just don't know how without seeing it (might not know how even then /forums/images/graemlins/wink.gif).
OK, I think there were three plastics tabs. I never thought of pushing them in though. Let me give that a go....stand by and thanx jimg
   / removing the PTO cover #5
I've seen one on which you just push the plastic tabs in, and I've also seen one on which you slide them all three to one side (in a slot), then lift them out.
Im digital camera challenged at the moment so I dont have any pics. Ill see what I can do tonight though.
Right, I *think* the tabs cant move side to side so Ill try pushing them in.
   / removing the PTO cover #8
One of my PTO's is Italian made. If the 3 tabs are slotted, take a screw driver and turn left a quarter turn, then pry the part that turned up and out. The remainder of the tab stays put.
First, thanx very much for all the help. In the end, just as a last ditch stab, I did a web search for eurocardan (PTO maker) and guess what? Their website has instructions for removing the cover. Wished I had thought to look on the web first. jimg
   / removing the PTO cover #10
Guys,
Here is a link to the info on the Eurocardan website for the instructions. I figure if anyone is searching in the future they can "get there from here".
Later days,
Michael
2016 MACK CXU613 DAY CAB (A52141)
2016 MACK CXU613...
1998 Volvo VN T/A Dump Truck (A50323)
1998 Volvo VN T/A...
CFG Industrial QK18R (A50121)
CFG Industrial...
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
