removing the PTO cover
   / removing the PTO cover
Thanx...I was going to post this when I finished the job. However, since you have I wont need to. /forums/images/graemlins/smile.gif I was surprised it was online...and better than the booklet which came w/ the PTO. It was one of those pics w/o words universal language things. Not all of the pics made sense and my PTO wasnt listed.
Anyway, Im half way thru the job and some of its not quite as easy as the instructions make it appear. Getting the ends pulled down the shaft is quiet difficult and Ive only managed one so far. Once its been pulled down the rest is very easy. It looks like assembly will go the same way as the joint cover somewhat flxible and doesnt want to line up neatly.
The other 'problem' is that the dealer left all sorts of metal shavings behind when he trimmed the shafts to length. Its an abrasive mess of metal bits, dust and grease which left a couple deep scuffs in the shaft.
   / removing the PTO cover #12
Be sure you replace all that 'gunky grease' on the shaft before putting it together. You want lots & lots of grease on these things. /forums/images/graemlins/smile.gif
--->Paul
   / removing the PTO cover #13
The Land Pride shaft is made by Euro Cardan a major Italian PTO company....see your LandPride dealer they should be able to get you a instruction / safety booklet on your PTO.
VERY IMPORTANT to keep your shields in place....should you not be able to get a booklet...let me know..I will send one to you....
edv
   / removing the PTO cover #14
On the topic of PTO shafts...
The S hook on the chain pulled the plastic tab off and now the plastic PTO spins when engaged. The plastic hole for the hook is completely gone, any suggestions? I was thinking of a plastic wire tie around the shaft and then connecting the S hook and chain to it. Any other ideas? I have the same PTO mfg, Eurocardan.
I was thinking about that just the other day and decided I could attach the chain to the yoke cover by popping a hole in it big enough to attach the chain hook. You could also make up a small metal bracket and rivet it in place too. I believe all thats required is a convenient or substantial attach pt. which keeps the chain pout of the moving parts. If the attach pts continue to fail b/c the chain is being pulled thru them then theres another problem.
Thanx for the offer. I did find the instructions online and have half the job done. The other half isnt coming apart so nicely and Im planning to have my dealer show me how it comes off. jimg
I dropped by the dealer this noon w/ the stubborn part. Turns out they had *lots* of trouble getting it off too. In the end a liberal application screw drivers and lubricating language got the thing apart. After it was apart the problem was obvious...the plastic had an exaggerated flare at the tab detent. This kept the tab from slipping over it w/o severe prying. The extra plastic got ground off so it would go on/off the same way the other half does. Look at the diagram at (which isnt entirely accurate):
http://www.eurocardan.it/english/documentazione-tecnica/Uso_Man_mont-smont-P14/Uso_Man_mont-smont-p14.html
The offending piece is #8. BTW parts 4, 3, 2/8 come off as a single unit. Tonight I plan to clean and lube the parts and store it all away until next spring. Thanx very much to all who responded! jimg
2020 John Deere 8245R MFWD Tractor (A53485)
2020 John Deere...
2025 Swict 78in Bucket Skid Steer Attachment (A55851)
2025 Swict 78in...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2018 Chevrolet Tahoe (A55973)
2018 Chevrolet...
Portable Restroom (A54865)
Portable Restroom...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
