Removing sweet gum stumps
   / Removing sweet gum stumps
I've taken out many sweet gum trees with my KX-91 mini (3.5 ton), many as big or larger as those pictured.
Let us know how it turns out.
It sounds like you have dug a lot of stumps. The technique you described was exactly what the pond digger did, except he didn't have to do a whole lot of digging with his giant machine. Too bad I didn't think ahead to let him take these out while he was here. But now I will have to deal with stumps; I had the trees cut last year. Thanks for the detailed suggestions. I'll try to take some pictures and post the results when I finish.
   / Removing sweet gum stumps #12
TonyF said:
One sweet gum OK. I can handle a few spiky balls. Hundreds of trees like I had and still have - no way, in the late fall the ground is so littered with the balls you can not walk on it. Somehow they get everywhere too.
They are tough trees and pretty in the fall. We had the tail end of a F1 tornado come by our property this April, lost 40+ pines, the sweet gums were still standing.:confused2: The ground was saturated with water from weeks of rain and the sweet gums with their massive roots held fast and just bent in the wind, the pines jumped out and laid down.
Ok. I could see that, the new ZD326 will do a number on those balls (from the tree that is) so I'm not too worried about this just one.
Ok so someone please explain it to me... What's wrong with sweet gums? I know they tend to be messy, but I have one that I just love. It's about 40 feet tall and I'm guessing 20 or so years old.
They are fine in the woods. In fact, I really enjoyed watching a pair of red tail hawks raise a family in a giant sweet gum in the woods nearby. And really big ones make great structure for a pond: Giant Sweet Gum Root Ball - Pond Boss Forum
But I do hate them out in areas where you walk.
   / Removing sweet gum stumps #14
I'm a fan of Sweetgums. Don't understand why they always seem to get bad press on this forum. Suppose people like digging things up with tractors around here.
   / Removing sweet gum stumps #15
I thought about hiring someone, but I enjoy this sort of work, and I need something to keep me out of trouble. :) I did get a quote from a stump grinder, and that would be a lot less money. But I need to do some grading and plowing to finish landscaping the area.
What are you intending to do with ten big ugly stumps once you get them out? Ridding yourself of them won't be easy and putting them somewhere may only make a mess that you will have to deal with at some other point in the future. Believe me I know running an excavator is fun, but in this case it would seem to make more sense to grind them and put the $$ saved into some other part of the landscape job.
I'll probably stack them in the burn pile and light them in a year or two. The stumps from the pond made a burn pile about thirty yards long, and it made a spectacular bonfire. And they provided cover for all sorts of critters in the meantime. But I may put a couple of the big ones in the pond like I did with the giant one.
   / Removing sweet gum stumps #17
What size machine took two hours to dig that stump? I hire a septic tank guy with a backhoe/loader to dig my stumps when I have just a few like you do. He has a 12 inch bucket with special forked teeth on it for digging stumps.
   / Removing sweet gum stumps #18
If the machine won't pick it up, those machines you mentioned should pick it up,there are a couple things you can do. Using the bucket cut one edge of the hole like ramp and roll it out, once its out, or on its side in the hole start picking at the roots with the bucket, breaking up the roots and dirt clod to lighten it, and believe it or not starting filling the hole. When you start filling wiggle the stump around with the bucket, the loose dirt will work itself under the stump and it will slooooowly rise up.
TonyF has it right.:thumbsup: I have dug ramps and drug them out and I have wacked away at the bottom of the root ball dirt with it laying on it's side to knock the dirt off to lighten it enough to lift it out of the hole. Ripping all the roots off you can after removing the dirt helps also.
Worst thing is you get seeping water in a deep hole that turns the dirt to mud and it forms a suction on the root ball.:mad: Good luck.
hugs, Brandi
I finally got back to the stump project this weekend, but the excavator I planned to rent was not available. So I rented a JD310 backhoe. Not as much fun as a big excavator, but it is doing the job. I got them to put on a 12 inch bucket, which I thought would be better at breaking the roots and digging a trench around the stumps. Most of the single stumps came out OK, and I was able to hook the 12" bucket around the stumps and carry them to the burn pile.
One of the stumps was much larger--a double stump about the same size as the one my friend had removed. This shows the double stump after I had about finished the basic trench around it.
http://i823.photobucket.com/albums/...rm/landscaping/StumpRemoval/IMG_5444_800w.jpg
Next I started working to pick some of the dirt off the bottom. That was pretty difficult, because the bucket would not extend enough to get under the stump unless I positioned the machine pretty far from the stump. This required moving the machine several times. By the time I finished this, I could wiggle the stump and break it loose. This is how it looked after this step.
http://i823.photobucket.com/albums/...rm/landscaping/StumpRemoval/IMG_5448_800w.jpg
Then I moved to the other side and managed to roll it out of the hole.
http://i823.photobucket.com/albums/...rm/landscaping/StumpRemoval/IMG_5452_800t.jpg
Here it is upside down just barely out of the hole.
http://i823.photobucket.com/albums/...rm/landscaping/StumpRemoval/IMG_5453_800t.jpg
It was still way to heavy to move, so I kept picking at the dirt between the two stumps.
http://i823.photobucket.com/albums/...rm/landscaping/StumpRemoval/IMG_5455_800w.jpg
It was still too heavy to pick up, but I was able to push it to the burn pile.
http://i823.photobucket.com/albums/...rm/landscaping/StumpRemoval/IMG_5458_800w.jpg
All in all, this has been so much fun that I have decided to convert from a weekend 8 hour rental to a weekly one and dig up all the old stumps that have made bush-hogging such a pain.
Thanks to all for the suggestions.
Charles
   / Removing sweet gum stumps #20
Charles
Charles,
Glad to hear you had so much fun.;) They are a blast and I love mine.:) I think a excavator would be that much more fun.:drool:
hugs, Brandi
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Case 5550 Trident (A56438)
2020 Case 5550...
John Deere 920 Grain Platform (A59814)
John Deere 920...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A56438)
2022 Greenworks...
