Removing steering wheel.
/ Removing steering wheel. #1
ka41
Louisiana
2009 L5240HST
I have a b3030 and was trying to remove the steering wheel. I removed the nut on top and tried to pull up on it but it would not come off. Pulls up about a quarter of an inch and thats it. Any suggestions.
Thanks
/ Removing steering wheel. #2
Pick up a steering wheel puller at your local parts store. There are usually 2 threaded holes on either side of the nut you took off. The puller will come with bolts to thread into the holes and through the puller tool. Tighten center pressure screw, wheel will pop loose. Probably buy or borrow the tool.
I looked and there are no center holes in the nut.
/ Removing steering wheel. #4
Do you have the factory service manual for this tractor? You should have.
/ Removing steering wheel. #5
Put some tension on the wheel by pulling it towards you, have a buddy hit the center nut area with teflon or rubber hammer. It will break loose, you shouldn't need a puller!
2005 Anderson 24ft T/A Dovetail Tag Trailer (A64556)
2005 Anderson 24ft...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
