Removing small dead trees - best way to pull
   / Removing small dead trees - best way to pull #51
There is this I've never done it it, But I have a friend that swears by it
   / Removing small dead trees - best way to pull #52
Just 'cause this thread has legs,
If I plan to pull stumps on small stuff, I still cut the tree off. at about as high as I safely can.
The Lever arm left attached to the root ball helps a lot., and clearing away the top gives a free space to work in. I like chains when I suspect the load is greater than the pull. If I know the load will move, wire rope is fine.
   / Removing small dead trees - best way to pull #53
I have hooks welded on my FEL but only for lifting with a chain or pulling bushes or tree limbs. Never to pull a tree that's still rooted in the ground. How about chain saw them short and renting a stump grinder. At least it would be less stress on the tractor and safer to you.
   / Removing small dead trees - best way to pull #54
You haven't said how big the trees are.
I have pulled trees since 1987 when I bought a Power Wagon with two PTO powered winches. I set the truck far away from the tree, use a ladder to climb 20' up the tree trunk. A 20 foot tall tree trunk is a heck of a lever. Most trees 24" and smaller come right out, stump & all.
24 years ago I bought my first full sized backhoe. I often push trees using leverage of the trunk. I haven't found a tree too big to push down, though I may have to rip some roots out first. Dead trees I DO NOT push. They might break & send widow makers my way. Plenty of people will say this isn't safe, but I prefer my odds inside a ROPS cab over standing at a tree with a chainsaw.
I am of the opinion that a compact tractor is too small to safely pull out any but small trees & shrubs.
As for pulling with a tractor, we are involved in antique tractor pulls. Pulling tractors are required to have wheelie bars to prevent backflips. My son & I have International Farmall M. Mine is 1940, Seth's is 1941. Neither has any risk of flipping but both are equipped with wheelie bars.
Leyland Cypress are basically Christmas trees. They are very fast growing and are often used to create a wall between neighbors. Not really a danger if dead or falls on you. It is soft, easily drug, and none more than 20 feet high even after 25 years. The stump rarely goes down more than 1-2’ but the roots can spread in all directions. By Spring these already brown trees will start falling over in a good wind. Cutting off the tops for now is not a horrible idea either.
Pulling out a few trees here and there has never been difficult, just time consuming. Pulling out 50-100 is another story. A bulldozer would work but many trees survived between dead ones so I can’t just mow everything down.
I wish I had something bigger than an L3200 but it is what I have without paying someone else to do the job. The question I will find out is whether it is enough or not.
   / Removing small dead trees - best way to pull #56
Yes chain will stretch, but the % (stored energy) is very low, measured in .001 percent of length while cable is measured in .1% (so MUCH more stored energy) which is what causes the break point to whip back at you.
Watched a GI get cut in half when a 500' 1/2" cable snapped at the far end. He was about 50' to the side and about in the middle of the pull. Kinda ruined his day.
i was a crane/wrecker operator in the corps back in the 80s. we were doing a tandem pull, and my partner's cable snapped. backlash cut a hunk out of him, and killed him. the amount of force that chains and cables store, when under strain, is nothing to take for granted.
   / Removing small dead trees - best way to pull #57
I'm currently paying $185/hr to have forestry mulching done. He gets more done in an hour than I can do in a full day with a small backhoe and tractor equipped with a grapple.
   / Removing small dead trees - best way to pull #58
I have a few dead apple trees from time to time. I have a BH92 and at first I cut them off low and dug them out. Too much of a mess.
Now I cut the smaller ones off at 2 1/2 to 3 feet and the larger ones with 10-11 inches at the stump off at 5 feet. I set my bucket on the top, push forward and backward to the ground twice and all of the roots are broke. All the ground here is red clay.
I hope to get a ripper tooth made for my backhoe this coming summer for spruce and hardwoods.
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
LOT OF I-BEAM (A58374)
PALLET OF MISC (A58374)
PALLET OF MISC...
2015 GATORMADE 45' - 10 TON GOOSENECK TRAILER (A52708)
2015 GATORMADE 45'...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
