Removing small dead trees - best way to pull
   / Removing small dead trees - best way to pull #41
A chain WILL whiplash if the pull is hard enough to break it. I've seen several videos of it, and done it myself. In each case it was the chain that broke, not the load breaking loose.
Watch at about 2:00+
Bruce
Yes chain will stretch, but the % (stored energy) is very low, measured in .001 percent of length while cable is measured in .1% (so MUCH more stored energy) which is what causes the break point to whip back at you.
Watched a GI get cut in half when a 500' 1/2" cable snapped at the far end. He was about 50' to the side and about in the middle of the pull. Kinda ruined his day.
   / Removing small dead trees - best way to pull #42
   / Removing small dead trees - best way to pull #43
Cut in half... I'd imagine it kinda ruined the day for everyone that witnessed it.
   / Removing small dead trees - best way to pull #44
I'm using my bucket and curl method described in an earlier post but there are lots of means to the same ends. I'm not doing this one below but it's safer than a chain and unbridled tension on it.
   / Removing small dead trees - best way to pull #45
For straight line pulls use a block/pully to change the angle and add force.
Can even change height to lower for the draw bar.
I have a small tractor and this works pretty well, keeping away from taller falling branches is easier too.
Bull rope damped works well.
   / Removing small dead trees - best way to pull #46
Due to the Louisiana drought this year (still happening), I’ve lost maybe 50 Leyland Cypress trees about 25 years old. I also lost a couple magnolias we planted at the same time which are clearly not coming back.
I’ve pulled the cypress before because after a year of being dead their roots are really weak so this will be my spring task.
The question is what gives me the most pulling power - is it best to pull backwards from the bucket end with a chain, or pull from the back end with a chain on the box blade?
With the box blade I can sometimes push on the tree to lean it one way, then use the chain to pull it out from the stump behind me.
Obviously I’d always like to push away so the tree doesn’t fall towards me but I believe I get more power with my L3200 by pulling but not sure if pulling from the back or front is best.
Watch this video by tractor rebuild guru Squatch253.
He uses a chain with a foundry hook to rip a couple of big roots and then the stump is easy.
I found a couple of heavy hooks on eBay.
And use the drawbar. It is much harder to flip pulling well below the axle.
   / Removing small dead trees - best way to pull #47
Lost my 55 year old father-in-law to a flipped tractor years ago. He was using it to drag trees thru the woods to de-limb them. My 12 year old brother-in-law watched it happen. Sad story. Since then I have NEVER dragged anything with a draw bar. My advice, think of some other way to solve your problem.
   / Removing small dead trees - best way to pull #48
I have a home made 800 lb counterweight for my JD 770. The counter weight has a low center of gravity. When I have to pull on something that looks like it will be a hard pull, I fill the loader bucket with dirt or gravel, then run the chain under the counter weight to the draw bar. I lower the counter weight until it's at the same height as the draw bar. If the front end wants to lift, it stops when the counter weight touches the ground and the rear wheels just spin. That's only happened once in a lot of times I've had to pull on trees, including dislodging the bottom end of some widow makers.
The weight in the loader bucket and the counter weight increase the pull of the tractor significantly.
I much prefer to pull with chain or synthetic pull ropes. I experienced a lot of broken chains pulling with big tractors on the farm in the 1950s. I've never had one snap and recoil very far. Chain doesn't stretch and accumulate stored energy like wire cable. It tends to just break and drop.
   / Removing small dead trees - best way to pull #49
By far the easiest way is a tree/post puller for about $1200.
   / Removing small dead trees - best way to pull #50
Using a wheel or a tire on a rim is usually the easiest way to pull stumps. I have never pulled trees down this way, but if you cut the tree and use the wheel/rim/tire, it isn't very bad. I have also seen a big stump pulled with a horse using a pole and pulling it against another tree.
Watch these videos and then make your decision.
Link to using wheel:
Link to using lever:
2013 Bell B35D Articulated Dump Truck (A59213)
2013 Bell B35D...
Dewalt D28493 7/9" Angle Grinder/Sander (A59076)
Dewalt D28493 7/9"...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2 Disc Heavy Duty Bottom Plow (A57454)
2 Disc Heavy Duty...
VERMEER PD10 PILE DRIVER (A52709)
VERMEER PD10 PILE...
