Removing Saplings with Bucket?
/ Removing Saplings with Bucket? #1
Anonymous Poster
Epic Contributor
I have heard of a "forked" device that attaches to bucket to hook and remove small trees 1-2" and brush? Any info on how to make or buy this thing?
thanks
/ Removing Saplings with Bucket? #2
There is a tool called the Brush Brute, that has been discussed on Jplan (just did the search), and also a reference to photo's on the JD 4000 Compact club (yahoo)
http://clubs.yahoo.com/clubs/johndeere4000seriestractors
under Tony's Toys album. It looks like a sickle mower bar without the sickle, and heavier teeth. It mounts on a FEL. But I havn't 'been there, done that' - yet.
/ Removing Saplings with Bucket? #4
Carl, I had one built for the three point hitch. There is a thread under "tree puller". As best as I remember TraderMark had a post with a picture of one. I took that picture and some measurements and one built for under $150. Works great, just make sure it is heavy enough..
/ Removing Saplings with Bucket? #5
/ Removing Saplings with Bucket? #6
<font color=blue>Robert Turk Jr.</font color=blue>
<font color=blue>Whitetail Splendor Deer Farms</font color=blue>
<font color=blue>Silver Creek, NY</font color=blue>
Where can I get a Brush Brute???
thanks
carl
/ Removing Saplings with Bucket? #9
Have seen posts that indicate the Brush Brute comes from Canada, and the price in the States is about $1000 (1500 Cdn). Also have seen mention of 2000 Cdn.
In April, Woodbeef posted the following info "The company is not online,but here's their contact info. D.D. Scissons Enterprises Ltd. RR#3 Smith's Falls,Ontario K7A 4S4 ph# 613-283-2082 fax# 613-283-9580".
This message was on 4/02/01 at 3:14 pm
Hope this helps.
/ Removing Saplings with Bucket? #10
I cant be bothered removing 1 and 2 inch saplings individually. I just cut them down with my brush hog. Of course, that leaves a small shattered stump at ground level, which may or may not be important depending on what you are going to do with the area in question.
/ Removing Saplings with Bucket? #11
Hey, hate to rain on anyones parade, but if you use this attachment on a JD 4300, your gonna break something. I use mostly, a 6' box blade on mine, and I have had several rock valves replaced and even shattered the rockshaft housing just the other day. I was NOT abusing the machine. The 4300 actually has more power than the rear attachments, and attachment points can handle. You back up into a tree with this device, "on a 4300" I hope your still under warranty. Just trying to save you all the heartache I have been suffering. Just dropped mine off this morning to get repaired, while there, I looked at several other models. I believe, starting out with the 4600 series, the rockshaft housing is much more massive and of different design, I asked for a quote on one.
look at the attachment, is a picture of broke housing, believe me, you don't want this
<P ID="edit"><FONT SIZE=-1>Edited by erisque on 11/19/01 07:52 PM (server time).</FONT></P>
/ Removing Saplings with Bucket? #12
erisque,
I have a JD 4100 and have pulled out 2-3" saplings.
The key to this is what kind of tree are you attacking. I wouldn't even attemp to pull an oak out. The tap root is too deep. I've had success with locust, box elder, and elm.
I use my 3pt hitch and a drawbar, clevis hook, and stout chain. I pull the saplings out slowly by pulling forward to break the roots and them use the rockbar to pull it out of the ground. If the tree refuses to move, go to plan B. Use the FEL with a toothbar. If that doesn't work. Wait for a contractor to come into your area with a backhoe and have him dig it out. /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
Terry
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
17394SFL (A61568)
17394SFL (A61568)
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
2010 Deere 318D (A60462)
2010 Deere 318D...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
