removing remaning bearing race
/ removing remaning bearing race #1
junglejry
ohio
farmall super c
help ! I have removed the two bearings from my motts roller ! but one of the bearings race is stuck ! how in the world, do you get that thing out ? thanks !!
/ removing remaning bearing race #2
Do you have access to a welder? If so, run a bead around the inside of the race and it will shrink the race.
If you dont have access to a welder, you might (carefully) cut through the race in a couple of spots and take it out in pieces.
Aaron Z
/ removing remaning bearing race #3
Help me here what kind of bearing. Tried to look up motts roller and im getting apple juice. If it's an outer race in a bore you have a few options: slide hammer puller, laying a weld bead on it and popping it out, modified prybars. If it's a pillow block get out the cuttoff wheels and don't hit the shaft.
thanks aaron, great idea ! was just kind of lost with how to do it !
thanks loadstar ! I'm not the best guy here to try and restore old mowers ! but everyone here has been great helping me out ! thanks again !
/ removing remaning bearing race #7
I'll 2nd run a bead around the center of the race and it will fall out when tapped.
/ removing remaning bearing race #8
Cut it out with a torch !
/ removing remaning bearing race #9
I have broken the races off with a cold chisel and hammer. Use two 2 lb hammers one as a backer.
Wear safety glasses.
I have also used a Dremel and cut them off. Just cut about half way through and hit with hammer.
Freeze it with CO2 or Freon and give it good hit.
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
1062 (A63291)
1062 (A63291)
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2014 IC Corporation PB105 School Bus (A64194)
2014 IC...
2017 Ford Fusion (A64557)
2017 Ford Fusion...
