Removing of pin?
   / Removing of pin? #1
minidiggerman01
lincoln, lincolnshire
kateuchi tb015
Hi, I was wondering if anyone could tell me how to remove the pin of the below images.
ImageShack® - Online Photo and Video Hosting
I've taken the pin/bolt out but wondered if the pin should knock straight out and or if there is side to knock it out. The reason for needing to remove the pin is because i can't get any grease into it, i have tried replacing the grease nipple but still the same.
This is a Takeuchi tb015
Thanks.
   / Removing of pin? #2
It should knock out either side now that you got the bolt out. Those pins can be really stubborn at times. Heat the pin bosses as a last resort if it refuses to move.
   / Removing of pin? #3
Big hammer!!!:laughing:
I would try from one side, if it moves, then over drive the pin back in from the other side. So you end up "wiggleling" it a little. Use oil where you can.
I'm not sure how much heat will help unless you use a whole lot of it.
Good luck, You'll need, those can be real tough.
I had to fix my dads back hoe last winter because grease would not go into one pin but he figured it would be fine, at least he was greasing 7 of 8 pins!?!:confused2: Guess which one seized and broke.
10222 (A56858)
10222 (A56858)
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
