Removing my FEL
/ Removing my FEL #1
Grand_Pooba
Wyoming County, NY
Bobcat CT230 & John Deere X324
Hi all,
I've had my CT230 for almost 3 years now and have never taken the FEL off. I just purchased a 72" KK rear finish mower and plan to use it to mow most of my 4 acre yard this summer. I'm trying to decide if I should take the loader off each time I mow, I don't have alot of things to mow around but I think it would be easier without it on. The question is does anyone else take it off, how long does it take and is it worth the effort.
Thanks,
Steve
/ Removing my FEL #2
It only takes a few minutes to remove and reinstall provided you have a level place to park it on. If leaving set on dirt put some blocks or plywood down to set the stands on. I have Quick Attach buckets so just take the bucket off which usually gives me the manuvering clearance I need when working the garden close to a fence line.
/ Removing my FEL #3
There are two videos from Bobcat on YouTube that detail removal and installation.
[ame=http://www.youtube.com/watch?v=ccgFP0DdE2I]Bobcat Compact Tractor Front-End Loader: Removal - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=PFhrYOTPElE]Bobcat Compact Tractor Front-End Loader: Installation - YouTube[/ame]
I found these helpful even though I have never removed my loader.
I did email the web site for them to myself so that when I do need to remove the loader the information is always available.
/ Removing my FEL #4
Take the bucket off if you have the Bob-Tach. If not...either leave on during mowing (heavier and less maneuverability) or remove it as per the video.
/ Removing my FEL #5
I second that
I have never found the need to remove my FEL arms, but when I am working in tight situations I do occasionally take off the bucket
/ Removing my FEL
I've got the pin on bucket so it's all or nothing. Haven't heard from anyone that's ever actually taken one off. The video looks real easy, but if you were making a video to sell a tractor you would most likely edit out all the "%*#$@" parts.
/ Removing my FEL #7
That is the reason I got a quick attach system. Why screw around removing/installing the FEL all the time when the bucket is the only real offending part when in tight spaces. I hate breaking the quick hydraulic disconnects. They dribble oil and then collect dust, Dirty hands or oily gloves is what you get. I just drop the bucket and run. The FEL can be removed and installed...would I want to do it once a year...sure. More than that...nope. You can adapt your pin-on bucket to a quick attach. Something to consider.
/ Removing my FEL #8
I took my loader off when I did my own 50 hour service for 2 reasons. Easy access and just to do it. It took me about 15 minutes to figure it all out, but I'm pretty sure I could have done it in 5 or less immediately after. It has been over a year now so it would probably take 15 minutes again since I would have to remember the steps.
I was intimidated by it at first, but trust me when I say this, after you do it once, you will think...pfff, that was easy.
Course, like most, I have a Quick-Attach, so I see virtually no reason to ever take the loader off. If I use my loader for at least 75% of my work, so I prefer it on. if I was using my tractor 90% of the time for mowing, I would probably take the loader off so it was out of the way and a little easier to see.
Ultimately, nothing wrong with taking it off just to learn how to do it. Then decide if the effort is worth it when you mow.
/ Removing my FEL #9
I have read several posts regarding people who have removed their pin on buckets, and after an hour or two and lots of cussing, they finally got the bucket back on
/ Removing my FEL #10
The quick attach is worth every penny to me not to have to be on my knees with a sledge hammer and alignment pins trying to make a bucket line up with pin holes.
/ Removing my FEL #11
I have the CK25 with the pin on bucket and it really only takes 5 minutes or so to put back on if it on gravel and can be shifted around a bit by hand. Once you get the first two pins in you just adjust the curl for the other two. Sometimes I take it off just to pull all the pins to clean all the grease joints/pins. I took the loader off last summer and found it could be taken on or off in 15 minutes. I could see having the quick attach for swapping implements often but I don't have much trouble getting the bucket on or off with the pins.
/ Removing my FEL #12
That is good, I am pretty sure you are the first person to have ever stated that, at least as far as I have read
:thumbsup:
/ Removing my FEL #13
It really is easy. One little trick. Use one hand to curl the bucket while you pull on the pin with your free hand. It will pop right out when you find the sweetspot. Do the same on the other side. If you haven't had it off in 3-4 years I imagine it will be a little more difficult the first time out.
The biggest pita is the hydraulic couplers, not a ton of access and they can hold some pressure.
Once you do it once or twice, it will truly be a 5 minute job.
/ Removing my FEL
Just an update. I removed the FEL before I did my mowing on Saturday and it was actually as easy as the video, go figure. About 3 minutes off and 5 back on. The hardest part, which wasn't that hard, was the couplings. Next time I will have a rag handy for the drips that leak out while disconnecting. I believe this we be standard practice when mowing.:)
/ Removing my FEL #15
I always take mine off when I mow. Very easy and truly a five minute job or less once you have done it a few times. Not only is it easier to maneuver around obstacles but it lowers the center of gravity of the machine somewhat so I feel a little more secure on sloping ground.
(INOP) TIGERCAT 720E FELLER BUNCHER (A64280)
(INOP) TIGERCAT...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
2018 Ford F-150 4x4 Pickup Truck (A61573)
2018 Ford F-150...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2022 Peterbilt 567...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
