3-Point Hitch Removing JD Deere 4600 PTO Solenoid
   / Removing JD Deere 4600 PTO Solenoid #1
dcraytor
Knoxville, MD
Deere 4600
I can't seem to find any directions to removing and replacing the PTO solenoid. There is a plastic nut on top of it, that seems to make not difference and when I try to turn the solenoid to unscrew it, the cover just turns. So, I can't quite figure out how to remove. From parts pictures, it looks like it screws on to the valve assembly.
Am I missing something here?....thanks in advance....Dan
   / Removing JD Deere 4600 PTO Solenoid #2
Is the solenoid part # AM878297 ?
According to JD parts it is. I was trying to get old one off to see the pin needs cleaning (solution from one of the posts, on PTO not working)....Dan
   / Removing JD Deere 4600 PTO Solenoid #4
2nd question.. is this for the mid-PTO engagement?
No, rear pto...I think the mid pto is mechanically activated with a pull lever.
But on this outside of the solenoid spinning, there looks like a center bolt sticking out that it spins around......Dan
   / Removing JD Deere 4600 PTO Solenoid #6
I find it in parts, but do not find how to remove it in the service tech manual.. will keep digging.
Thanks, only thing I found in the service manual was hot to test it to see if it's working....Dan
K,
So, I went down to Deere shop, had a solenoid. Basically, there is a plastic nut that holds the outside of the solenoid to inside piece, so the outside should have slid off, but due to whatever, I still could not get it to slide off, so, I took a grinder to it. After I got the outside cover off, I could then hit the bottom with a punch and start it turning off.
I replaced the solendoid, being care for the small pin on the inside of it that's really easy to loose. It still did not work. So, I took off solenoid, and tapped the inside valve which the solenid is suppsed to move. It was stuck, but bounced loosed after it punched it a little. So I think something either from the backhoe or the 3rd hydraulic line, got some sort of junk in the hydraulic line. I removed the valve and also start engine for a sec to let some fluid run out with valve removed.
That fixed it....Thanks for your help.....Dan
   / Removing JD Deere 4600 PTO Solenoid #9
:thumbsup: Good to hear.
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
KJ 20' Metal Farm Driveway Gate (A53314)
KJ 20' Metal Farm...
Peterbilt 377 Semi-Truck (A56435)
Peterbilt 377...
