removing gravel
   / removing gravel #1
kramarj
Durand, Illinois
Kubota B7100 w/1630C Loader
i am trying to remove really hard packed gravel from my driveway with a kubota b7100 with the loader and i am not really getting anywhere, i tried using the toothbar and still nothing, anybody have any ideas, thanks
   / removing gravel #2
if you have a box blade you might try using the rippers down 1 or 2 notches that way it breaks up the packed surface otherwise you are going to be in trouble.
mark
   / removing gravel
i have a box blade, but it is homemade and it doesnt have rippers
would getting it wet help loosen it up enough to dig down further
   / removing gravel #4
I think the B7100 is just too light to have any effect on hard packed gravel... Is there a farm nearby that has a heavy cultivator, chisel or ripper ?
   / removing gravel
thats what im thinking i think i am just going to rent a skidloader or bigger tractor, thanks for the input
   / removing gravel #7
A box blade with the rippers down will do the job of breaking it up.
   / removing gravel #8
Have you tried the loader with toothbar pointed straight down? This is how I broke up some ground where I put in my rain garden. My 4010 probably isn't much heavier than your B7100.
Ralph
   / removing gravel
i tried the toothbar going forward angled down, but not trying to drag backwards, i think the gravel is just too packed down from driving on it over the years, but i will try
   / removing gravel #10
Try getting under the edge of it. Compacted gravel has allot of strength as long as it's in place, but when you get under it, you can break it up real easy. Concrete works this way too, but it's not as easy.
For pipe or conduit, I use a pick and start at the edge. I dig under the gravel and into the dirt, and it just falls apart. Then I just keep working my way across. I can cross my gravel driveway in an hour this way.
Good luck,
Eddie
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
flooring (A53424)
flooring (A53424)
1999 Yamaha G16A Utility Cart (A52377)
1999 Yamaha G16A...
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
