Removing female quick release coupling
/ Removing female quick release coupling #1
asblair
Guildford
Case
I have a stubborn female coupling on my case 78, I have bought a new part to replace it but just can't get it off. I've tried all sorts, does anyone know of any tricks/tools used to remove it?
Much appreciated.
/ Removing female quick release coupling #2
Welcome to TBN.
Pic of fitting would help us to figure out a solution.
/ Removing female quick release coupling #3
Do want to remove the female quick release coupling from the line it is screwed into... Or are you having trouble getting the male end out of the female quick release coupling...
/ Removing female quick release coupling #4
If it's rusted, pour some penetrating oil to it,
if you can't get it out, replace both male and female.
/ Removing female quick release coupling #5
Much appreciated.
Remove any pressure first.
Pliers to turn the barrel of the coupler and then pull or push the barrel to release the male coupler.
/ Removing female quick release coupling #6
Much appreciated.
Heat ...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2015 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2015 Autocar...
Shuttle Bus (A66736)
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
2018 FREIGHTLINER CASCADIA 125 6X4 T/S SLEEPER TRUCK TRACTOR (A69167)
2018 FREIGHTLINER...
2012 SPARTAN GLADIATOR FIRE TRUCK (A66091)
2012 SPARTAN...
