Removing female quick release coupling
/ Removing female quick release coupling #1
asblair
Guildford
Case
I have a stubborn female coupling on my case 78, I have bought a new part to replace it but just can't get it off. I've tried all sorts, does anyone know of any tricks/tools used to remove it?
Much appreciated.
/ Removing female quick release coupling #2
Welcome to TBN.
Pic of fitting would help us to figure out a solution.
/ Removing female quick release coupling #3
Do want to remove the female quick release coupling from the line it is screwed into... Or are you having trouble getting the male end out of the female quick release coupling...
/ Removing female quick release coupling #4
If it's rusted, pour some penetrating oil to it,
if you can't get it out, replace both male and female.
/ Removing female quick release coupling #5
Much appreciated.
Remove any pressure first.
Pliers to turn the barrel of the coupler and then pull or push the barrel to release the male coupler.
/ Removing female quick release coupling #6
Much appreciated.
Heat ...
Kenworth T6 (A63688)
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
2022 John Deere 5055E (A64126)
2022 John Deere...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
Cat 312 Excavator (A62679)
Cat 312 Excavator...
