Removing female quick release coupling
/ Removing female quick release coupling #1
asblair
Guildford
Case
I have a stubborn female coupling on my case 78, I have bought a new part to replace it but just can't get it off. I've tried all sorts, does anyone know of any tricks/tools used to remove it?
Much appreciated.
/ Removing female quick release coupling #2
Welcome to TBN.
Pic of fitting would help us to figure out a solution.
/ Removing female quick release coupling #3
Do want to remove the female quick release coupling from the line it is screwed into... Or are you having trouble getting the male end out of the female quick release coupling...
/ Removing female quick release coupling #4
If it's rusted, pour some penetrating oil to it,
if you can't get it out, replace both male and female.
/ Removing female quick release coupling #5
Much appreciated.
Remove any pressure first.
Pliers to turn the barrel of the coupler and then pull or push the barrel to release the male coupler.
/ Removing female quick release coupling #6
Much appreciated.
Heat ...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Chevrolet...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
