Removing engine cover - bx-25
/ Removing engine cover - bx-25 #1
Tachdriver
Kubota bx25
Is it absolutely necessary to remove the FEL in order to remove the Engine side cover ?
later
I need to get to the oil psi sender.....
later
/ Removing engine cover - bx-25 #3
On my BX23, I need to remove the brush guard and side covers. I just raise the bucket to do this. you can place a step ladder under it for saftey purposes....you'll only bang your head once on the bucket....after that you won't forget its there....
Ok thanks, I was going to jam a 2x6 in to hold the bucket up
later
/ Removing engine cover - bx-25 #6
its not necessary, but its easier and safer dont you think ? the FEL comes off in less then 5 mins anyways so no biggie. If you dont take it off, be sure to engage the FEL control lock and use 2X6 like you were thinking of.
Its just makes me uneasy with something that much weight over my head, so if I were you , just take it off.
/ Removing engine cover - bx-25 #7
later
I would take it off...It only takes a couple on minutes...You also need to remove the brush guard...:thumbsup:
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
