Removing engine cover - bx-25
/ Removing engine cover - bx-25 #1
Tachdriver
Kubota bx25
Is it absolutely necessary to remove the FEL in order to remove the Engine side cover ?
later
I need to get to the oil psi sender.....
later
/ Removing engine cover - bx-25 #3
On my BX23, I need to remove the brush guard and side covers. I just raise the bucket to do this. you can place a step ladder under it for saftey purposes....you'll only bang your head once on the bucket....after that you won't forget its there....
Ok thanks, I was going to jam a 2x6 in to hold the bucket up
later
/ Removing engine cover - bx-25 #6
its not necessary, but its easier and safer dont you think ? the FEL comes off in less then 5 mins anyways so no biggie. If you dont take it off, be sure to engage the FEL control lock and use 2X6 like you were thinking of.
Its just makes me uneasy with something that much weight over my head, so if I were you , just take it off.
/ Removing engine cover - bx-25 #7
later
I would take it off...It only takes a couple on minutes...You also need to remove the brush guard...:thumbsup:
12T Grain Bin (A65579)
2017 TAKEUCHI TL8 SKID STEER (A65053)
2017 TAKEUCHI TL8...
2001 International 3800 School Bus (A64194)
2001 International...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
Stout Buckets HD72-3 Brush Grapple Skid Steer Bucket (A65640)
Stout Buckets...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
