Removing engine cover - bx-25
/ Removing engine cover - bx-25 #1
Tachdriver
Kubota bx25
Is it absolutely necessary to remove the FEL in order to remove the Engine side cover ?
later
I need to get to the oil psi sender.....
later
/ Removing engine cover - bx-25 #3
On my BX23, I need to remove the brush guard and side covers. I just raise the bucket to do this. you can place a step ladder under it for saftey purposes....you'll only bang your head once on the bucket....after that you won't forget its there....
Ok thanks, I was going to jam a 2x6 in to hold the bucket up
later
/ Removing engine cover - bx-25 #6
its not necessary, but its easier and safer dont you think ? the FEL comes off in less then 5 mins anyways so no biggie. If you dont take it off, be sure to engage the FEL control lock and use 2X6 like you were thinking of.
Its just makes me uneasy with something that much weight over my head, so if I were you , just take it off.
/ Removing engine cover - bx-25 #7
later
I would take it off...It only takes a couple on minutes...You also need to remove the brush guard...:thumbsup:
John Deere L100A Riding Mower (A65579)
John Deere L100A...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2017 WEILER P265 ASPHALT PAVER (A65053)
2017 WEILER P265...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
2022 EZ-GO ELITE...
