Removing christmas trees stumps
   / Removing christmas trees stumps #51
I've got 30 acres full of cedar trees that I've been slowly clearing. The tree sizes range from small to quite large. My method is to use a backhoe to rip the lateral roots out, and then use the tractor/grapple to push the tree over and grab it with the grapple and haul it to a burn pile.
My method is effective, but slow. It's a losing proposition on 30 acres. I'm about ready to just hire a dozer for 2 or 3 days and then deal with the cleanup mess that I know will be facing me.
   / Removing christmas trees stumps #52
I didn't read all the posts because I know what worked for me: I used a super duty, 125 hp rated single shank ripper on a 90hp tractor in 4wd and drove over the top and popped out almost every one of my stumps. No big deal.
What didn't work is a small backhoe. I had to move multiple times and left holes and roots sticking out and stumps full of dirt.
   / Removing christmas trees stumps #53
The species of tree that was used for Christmas trees could be a huge variable in what you need to remove them.
When we were running a 30,000 tree Christmas tree operation, we planted trees that were genetically created by Texas A&M just for use as Christmas trees.
The stumps of these trees would rot very quickly and we could remove them by kicking with a boot aprox 14 - 15 months after the tree was cut.
A moldboard plow would have no problems at all in one of these fields a year after cutting.
I'd suggest you find out what species of tree stump you're dealing with, then research how fast they will rot in your environment.
   / Removing christmas trees stumps #55
At 3 feet per second, it would take 20 or 30 hours just to walk along and kick them all.
It would take me longer, I only have 2 feet each second
   / Removing christmas trees stumps #56
   / Removing christmas trees stumps #57
Slash and burn
Just a follow up on my stumps. Had a John Deere 35 come in this w-end. Removed 750 stumps,
took 6-7 hours. Gives me the room for a food plot. Balance of them still rotting. Only solution I found.
Cheers
Cushman Cart (A55853)
2010 Ford Transit Connect Cargo Van (A53422)
2010 Ford Transit...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2006 Acura RL Sedan (A55853)
2006 Acura RL...
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
UNUSED WOLVERINE MCB-11 48W 48" HYD 4N1 BUCKET (A57193)
UNUSED WOLVERINE...
