Rotary Cutter Removing blades on brush cutter
   / Removing blades on brush cutter #11
Found the attached instructions out on the web.
Haven't tried it yet but it seems to match the instructions for the mowers which had the maintenance plate installed by the factory.
   / Removing blades on brush cutter #12
I go about it in one of 2 ways.
1st, and most commonly, I leave the mower attached to the tractor, raise the mower (with the 3-point hitch) and put jackstands under the skid rails. I still don't "get under" the mower any farther than just my arms. I have all Bush Hog mowers. (6 different ones currently) They have access openings on the top of the deck to reach the nut/bolt. I use an impact wrench to remove the nut, a punch to drive the bolt out, and then reach under the mower to replace the blade/bolt, re-installing the nut from above.
2nd method is essentially the same, except I hang the rear of the mower off one of my trailers with the front still attached to the tractor.
I sharpen blades in place, using much the same procedure(s).
   / Removing blades on brush cutter #13
Do you really have to be sure the blades are not turning before removing them???:D
   / Removing blades on brush cutter #14
I'll bet that when I was young and quick I could have gotten a socket on a spinning blade. But no more, I have to wait for them to stop. Such a waste of time :D
   / Removing blades on brush cutter #15
And the irony is, time is the one thing we have so much less of, than when we were younger....
Whatever you do, I'd recommend you hit the threads with some PB Blaster penetrating oil before starting. Just looking at the size of those lugs/nuts, and given the conditions under which something like a mower lives, they're not gonna come easy.
Anybody know the typical torque setting, when it comes time to reinstall? Yeah, it's gonna vary with the mower, size, etc., but ball park?
   / Removing blades on brush cutter #16
On mine, I remove the tail wheel by taking out a couple bolts. Then I can insert a big socket into a hole in the top to get to the nuts on the bolts holding the swing blades. I remove them with a 6' pipe wrench over my socket handle initially, then just use a ratchet handle.
To put them back, I use a couple quick-connect clamps to hold the stump jumper and bolt in place. I use the 6' pipe wrench to "torque" the nuts, just need to judge when I've applied about 80# of push or when the nuts just won't move any more.
I just raise the back of the unit with a floor jack and insert a couple jack stands underneath the back of the unit. There's plenty of room on mine doing this.
Don't see what flipping it over would accomplish other than letter oil come out of the gear box breather and make a mess.
Ralph
   / Removing blades on brush cutter #17
My Bush Hog says the torque is 650 ft/lbs. Remember we're talking a 1 11/16 nut and bolt.
Why they couldn't have gone with 1 3/4 nut and bolt is beyond me.
Wedge
   / Removing blades on brush cutter #18
Don't forget to retorque those nuts after running the mower for a few hours. I find that they always need to be tightened once after the installation. It is bad news to have a blade come off while mowing.
Also, no need to remove the blades unless you are replacing them. Just sharpen while on the mower and for this activity there is some benefit to flipping the mower on its side. Though I don't do it, I simply reach under the mower with the 4.5" grinder with the mower hanging over the edge of the trailer.
Thanks everyone for all the responses. I'm a bit embarrassed to admit that I had never noticed or paid any attention to the inspection cover on top of the cutter. I pulled it off this weekend and low and behold, there was the nut that attaches the blades to the stump jumper.
The cutter is about 25 years old and has had a rough life. The blades are in bad shape so I'll probably go ahead and replace them. Again thanks for all the replies.
   / Removing blades on brush cutter #20
So to overcome the bad luck...over which shoulder do you throw the loose blade?...:D
2006 MACK CXN613 FLATTOP SLEEPER (A55745)
2006 MACK CXN613...
30ft Highway Trailer Co. Lowboy (A55315)
30ft Highway...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
