Backhoe Removing backhoe bushings
   / Removing backhoe bushings #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I found the swing pivot bushings on my Woods 9000 backhoe damaged when I pulled the main pins this past weekend. One is particulary trashed with a gap in the teflon (or whatever is in there) about a third of the way around. Can they be punched out (like motorcycle wheel bearings), or do they have to be pressed? Any good backyard methods of changing them?
Thanks - JayC
(btt)
Come on, SOMEBODY must've changed pin bushings at least once...
Thanx - JayC
   / Removing backhoe bushings #3
Jay4200 said:
(btt)
Thanx - JayC
Jay, I never have learned how to link to other threads but if you do a search for “Replacing hoe pins and bushings” you’ll find some ideas guys gave me. I’ve yet to do it myself so I don’t have any practical experience to share. Maybe the thread will give you some ideas.
MarkV
Thanks Mark -
I found your thread - it sounds like the bushings can be pressed out just like on a dirtbike. I'm no stranger to making pullers/pushers, but I've never done it for anything this big ;). If they can be pressed out with a threaded-rod puller, I'd wager that they could be tapped out with a punch too.
JayC
   / Removing backhoe bushings #5
Jay,
I was thinking about you making a home made puller. You just need a threaded rod (1" or so) and several larger washers, 1 steel plate with a hole in it and several nuts. The force from a threaded rod works really well for pulling stuck hardware.
Let me know if you get the bushing out.
Design.
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
Wolverine Mini Skid Steer Grapple Bucket (A50514)
Wolverine Mini...
2005 TerraGator 8104 (A52748)
2005 TerraGator...
(8) 2 PLUG VALVES (A52472)
(8) 2 PLUG VALVES...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
