removing a tree stump (how to)
   / removing a tree stump (how to) #11
As you say it's in your backyard you probably have an extension cord that's long enough.
Just be sure your saw is grounded or double insulated. This comes to my mind from the other thread on outlets wired backwards.
   / removing a tree stump (how to) #12
Shovel and Axe and lots of time. Be careful with the come along and don't bring another tree down.:D
Water the area well so the digging is easier.:D
   / removing a tree stump (how to) #13
first of all - don't brushoff the heavy equipment option. you say you have a gate-- how wide is it ? A wooden fence can be unscrewed and moved for a backhoe and put back. SCUT like mine can squeeze in a 4 ft gate. I dug up maple stumps that had roots deeper the 4 ft in ground. What kind of tree was it ? softwood? maple? pine? A walk behind stump grinder will fit through almost any gate. It pretty much 20 inches wide. A stump in foot diameter will be gone in no time so a 4 hour rental is all you need.
Or if time is on your side and low money, I'd go with the route other said. move as much dirt you can from sides of stump and get to cutting with a chainsaw. cut so the stump is just below the surface so you can mow over it.plan on replacing the chains a few times due to dirt.
got a axe? chip away everyday for an half hour or longer if you can stand it for a month or so, it will be gone in no time. :D
   / removing a tree stump (how to) #14
Here's what I meant about the walk behind stumpginders -
You should be able to get something like that through a gate.
23222 (A50323)
23222 (A50323)
2005 Ford Explorer 4X4 SUV (A53424)
2005 Ford Explorer...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
(INOP) JOHN DEERE 160P EXCAVATOR (A54756)
(INOP) JOHN DEERE...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
