removing a tree stump (how to)
   / removing a tree stump (how to) #11
As you say it's in your backyard you probably have an extension cord that's long enough.
Just be sure your saw is grounded or double insulated. This comes to my mind from the other thread on outlets wired backwards.
   / removing a tree stump (how to) #12
Shovel and Axe and lots of time. Be careful with the come along and don't bring another tree down.:D
Water the area well so the digging is easier.:D
   / removing a tree stump (how to) #13
first of all - don't brushoff the heavy equipment option. you say you have a gate-- how wide is it ? A wooden fence can be unscrewed and moved for a backhoe and put back. SCUT like mine can squeeze in a 4 ft gate. I dug up maple stumps that had roots deeper the 4 ft in ground. What kind of tree was it ? softwood? maple? pine? A walk behind stump grinder will fit through almost any gate. It pretty much 20 inches wide. A stump in foot diameter will be gone in no time so a 4 hour rental is all you need.
Or if time is on your side and low money, I'd go with the route other said. move as much dirt you can from sides of stump and get to cutting with a chainsaw. cut so the stump is just below the surface so you can mow over it.plan on replacing the chains a few times due to dirt.
got a axe? chip away everyday for an half hour or longer if you can stand it for a month or so, it will be gone in no time. :D
   / removing a tree stump (how to) #14
Here's what I meant about the walk behind stumpginders -
You should be able to get something like that through a gate.
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
2006 Isuzu NPR 16ft Box Truck (A55788)
2006 Isuzu NPR...
60" X 39" TRAILER TAILGATES (A54756)
60" X 39" TRAILER...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
