Removing a "roll pin"
   / Removing a "roll pin"
Re: Removing a \"roll pin\"
OK it is done.
Attempt number 1. I hammered it flush with one side so most of it was sticking out the other side. I took a good stout nail and flattened the point. I used the head against the roll pin, the flattened point was facing away for me to hammer onto. It promptly bent 90 degrees.
Attempt number 2. Same result, except I hit my finger with the hammer.
Attempt number 3. Larger nail, much larger. Cut off the point and with the newly flat end pressed against the roll pin I wacked at it with my hammer. I should have been wearing heavy gloves, see Attempt number 2. This time there were a few swear words, but they were pain induced, not out of frustration.
Attempt number 4. I took a pair a wire snips and gingerly squeezed into the roll pin and rocked it. It took some time, but it acually pulled out.
   / Removing a "roll pin" #12
Precisely the way I've done it, several times, Bob, before I got the right kind of punches. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
Well I don't have the punches so if I ever have to do it again I will first try the "Bird" method!
Thanks. And by the way, rocking the pins out hurt a lot less than hitting my fingers with the hammer /forums/images/graemlins/blush.gif
   / Removing a "roll pin" #14
I run a small gunsmithing business on the side. A number of years ago I purchased a special set of roll pin punches from Brownells after being frustrated many times using a straight pin punch. The roll pin punch has a dimpled end that fits into the opening of the roll pin. This arrangement does not flatten the pin thus making it reusable and easier to get out.
I don't have the latest catalog handy right now but I know they are not very expensive.
   / Removing a "roll pin" #15
Brownells sells them for $3.60 each, or a set of 8 including "bench box" $35.50
   / Removing a "roll pin" #16
The secret to tapping them out is to use the blunt nose punch so that you don't expand them. I also 1st give them a shot of PB Blaster and they slide out easier.
</font><font color="blue" class="small">( The secret to tapping them out is to use the blunt nose punch so that you don't expand them. I also 1st give them a shot of PB Blaster and they slide out easier. )</font>
A little late with that advice Mike! I didn't even think about using a lubricant /forums/images/graemlins/frown.gif
   / Removing a "roll pin" #18
Bob I only added the late post because a lot of folks read these posts for their own reference. They might also have the need to remove a pin or two at sometime in the future. And after all information is "free" here at the TBN site.
Hope you had a good 4th!
   / Removing a "roll pin" #19
</font><font color="blue" class="small">( A number of years ago I purchased a special set of roll pin punches from Brownells after being frustrated many times using a straight pin punch.)</font>
A nice set well worth the price !
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2019 CATERPILLAR 257D SKID STEER (A50458)
2019 CATERPILLAR...
2005 CATERPILLAR 420D BACKHOE (A50458)
2005 CATERPILLAR...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
