Remove tire fluid ballast
   / Remove tire fluid ballast #11
ditto that. remove the tires.. wash out.. wash rim.. remove any rust.. chemically convert.. then repaint.
reseat tire. perhaps dump in a quart of water and antifreeze, mixed at say 70% af..
soundguy
Never heard of that one. What's that for?
   / Remove tire fluid ballast #12
almost impossible to get cacl out of a tire casing. That's why I run tubes if I run cacl.
the antifreeze has corrosion inhibitors, so.. even after you wash that tire casing out good, it will still have salt permieated in it. the af fluid sloshing around in there should keep corrosion in check.. especially if you got th emetal prepped and painted good.
I like an epoxy primer and paint. very tough. if you use 2-3 coats and let it cure properly, you can generally get a tire back on without removing ALL the paint on the rim too.
soundguy
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
Craftsman 42 Inch Riding Mower (A57453)
Craftsman 42 Inch...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59575)
2019 WABASH...
207279 (A52708)
207279 (A52708)
