Remove plow from loader and mount on tractor
   / Remove plow from loader and mount on tractor #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
I currently have a snow plow mounted on my loader boom with angles controlled by a rear outlet. I want to get it off the boom, remove the loader and mount the blade directly to the front of the tractor. Can I use the four outlets that supply the loader and use the loader joystick to control up-down-right-left with it?
   / Remove plow from loader and mount on tractor #2
Yep sure can OEM front mount plows do what your talking about
   / Remove plow from loader and mount on tractor #3
Shouldn't be a problem. That's how the blade is controlled on our BX2660.
Aaron Z
   / Remove plow from loader and mount on tractor #4
What does your current setup look like? What's wrong with the way it is?
I have a 9' commercial blade weighs about 1K. I plow a 2-1/2 mile piece of road that our county doesn't maintain. I know it's putting a lot of linear stress on the loader boom and it acts like a big lever pushing the front of the tractor all over. I don't want to damage the loader a I want to make the tractor more proficient at pushing snow on the roadway.
QUOTE=davel8257;3591055]What does your current setup look like? What's wrong with the way it is?[/QUOTE]
   / Remove plow from loader and mount on tractor #6
How are you going to mount it to the front of the tractor?
My plow has a Meyer A frame. I am going to buy a heavy duty Meyer truck mount and fab it to fit the tractor. Bolt on so I can remove it when the time comes.
   / Remove plow from loader and mount on tractor #8
Look up a thread by ASGAR, I copied his design twice. Once for a B series tractor and once again for an L series tractor. Currently using the L series still to plow the driveway. I mounted the subframe to the loader support for the push frame and the brush guard has a nice little lip to hang the front end from. It all bolts together and has 0 slop. The lifting post quicklydisconnects so that the loader can be put back on for our normal everyday tasks. I would never mounted a plow on the loader after using this set-up. I have some pictures of my build in that build thread. Subframe Snow Plow
Your set up looks great! I had similar in mind just wasn't sure if there were any reason I couldn't use the loader control for the plow operation.
   / Remove plow from loader and mount on tractor #10
It's very easy to match up the A frame of your plow to the tractor undercarriage. I use two square tubing beams dropped forward and down from what used to be the mid-mower mounts. Its attached with studded spherical joints. I have it as close to the front weight bar as possible to allow full plow angling in both directions. I use a double acting cylinder for up/down so I can crack ice buildups using reverse gears. The two single acting OEW plow cylinders are connected in anti-parallel which produces a double acting effect. I used car brake lines to restrict the flow to the angle cylinders. The loader joystick controls make the snow and gravel plow a natural tool. I added two extra trip springs to keep things moving without hiccups. I have shimmed the skid shoes so that the plow blade rides about 1/4 to 3/8 inch above the driveway gravel.
No problems steering or moving any type of snow at any angle and with any road gear. I can outrun cars trying to follow me down my dead-ended road. Extra front weight and loaded rear tires are the only other recommendations. This tractor has 4 wheel drive and left/right brake steer for zero radius turns. When I finish with my 800' driveway and the horseshoe turnaround, the machine has not even warmed up fully.
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
