Remove plow from loader and mount on tractor
   / Remove plow from loader and mount on tractor #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
I currently have a snow plow mounted on my loader boom with angles controlled by a rear outlet. I want to get it off the boom, remove the loader and mount the blade directly to the front of the tractor. Can I use the four outlets that supply the loader and use the loader joystick to control up-down-right-left with it?
   / Remove plow from loader and mount on tractor #2
Yep sure can OEM front mount plows do what your talking about
   / Remove plow from loader and mount on tractor #3
Shouldn't be a problem. That's how the blade is controlled on our BX2660.
Aaron Z
   / Remove plow from loader and mount on tractor #4
What does your current setup look like? What's wrong with the way it is?
I have a 9' commercial blade weighs about 1K. I plow a 2-1/2 mile piece of road that our county doesn't maintain. I know it's putting a lot of linear stress on the loader boom and it acts like a big lever pushing the front of the tractor all over. I don't want to damage the loader a I want to make the tractor more proficient at pushing snow on the roadway.
QUOTE=davel8257;3591055]What does your current setup look like? What's wrong with the way it is?[/QUOTE]
   / Remove plow from loader and mount on tractor #6
How are you going to mount it to the front of the tractor?
My plow has a Meyer A frame. I am going to buy a heavy duty Meyer truck mount and fab it to fit the tractor. Bolt on so I can remove it when the time comes.
   / Remove plow from loader and mount on tractor #8
Look up a thread by ASGAR, I copied his design twice. Once for a B series tractor and once again for an L series tractor. Currently using the L series still to plow the driveway. I mounted the subframe to the loader support for the push frame and the brush guard has a nice little lip to hang the front end from. It all bolts together and has 0 slop. The lifting post quicklydisconnects so that the loader can be put back on for our normal everyday tasks. I would never mounted a plow on the loader after using this set-up. I have some pictures of my build in that build thread. Subframe Snow Plow
Your set up looks great! I had similar in mind just wasn't sure if there were any reason I couldn't use the loader control for the plow operation.
   / Remove plow from loader and mount on tractor #10
It's very easy to match up the A frame of your plow to the tractor undercarriage. I use two square tubing beams dropped forward and down from what used to be the mid-mower mounts. Its attached with studded spherical joints. I have it as close to the front weight bar as possible to allow full plow angling in both directions. I use a double acting cylinder for up/down so I can crack ice buildups using reverse gears. The two single acting OEW plow cylinders are connected in anti-parallel which produces a double acting effect. I used car brake lines to restrict the flow to the angle cylinders. The loader joystick controls make the snow and gravel plow a natural tool. I added two extra trip springs to keep things moving without hiccups. I have shimmed the skid shoes so that the plow blade rides about 1/4 to 3/8 inch above the driveway gravel.
No problems steering or moving any type of snow at any angle and with any road gear. I can outrun cars trying to follow me down my dead-ended road. Extra front weight and loaded rear tires are the only other recommendations. This tractor has 4 wheel drive and left/right brake steer for zero radius turns. When I finish with my 800' driveway and the horseshoe turnaround, the machine has not even warmed up fully.
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A54757)
UNUSED RAYTREE...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2007 BOMAG BW120AD SMOOTH DBL DRUM ROLLER (A52705)
2007 BOMAG BW120AD...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
