Remove Gear Shift Knob
   / Remove Gear Shift Knob #1
mlong75107
Norco, CA
1980 Kubota B7100
I have an older B7100D and need to replace the gear shift boot. I have acquired the boot, but cannot get the gear shift knob off. There is a hole in the middle, if that helps. Any ideas?
   / Remove Gear Shift Knob #2
G'day Mate and welcome to TBN from Downunder.
Gear Shift Knob removal has come up recently in other threads. The consensus seems to be that the knobs are on there permanently and need to be cut off.
Have a look at the bottom of this page in "Similar Threads"... your answer may lay there.
   / Remove Gear Shift Knob #3
Mine are plastic and I believe simply pressed on. Heat would soften the plastic and you should be able to then pry the knob off.
I re-installed my knob by stuffing with hot glue and pushing into place.
   / Remove Gear Shift Knob #4
Heat gun.
Fix something like a pair of vise-grips below the knob, and pry off after careful heating. Heat again, reapply, tap in place
Worked pretty well on my 7610.
2010 Ford Edge Limited AWD SUV (A51694)
2010 Ford Edge...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2000 Chevy 3500 Wrecker Truck (A52384)
2000 Chevy 3500...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2019 Nissan Frontier Pickup Truck (A51692)
2019 Nissan...
