Remove and reinstall old tires?
   / Remove and reinstall old tires?
On further inspection, the sidewall on one of the tires is delaminating. I expect the tires will not survive a re-mount... so I'll take the band-aid approach for now to see how many years I can squeeze out of these before restoring the tractor (something I hope to do anyhow).
Thanks - Chris
   / Remove and reinstall old tires? #12
i deffinately would not try to remount a delaminating tire. bead may seperate and that is dangerous.
if the core of the valve stem is leaking.. that's a pretty easy fix. if it's leaking from around the stem on a tube tire.. tube has a hole.
if it is tubeless, you can actually get a tool to pop the old stem out and then clean the hole.. then put a new one in, from the outside. pretty much squeezes a stem into a pipe that is shoved intot he hole, and then the stem popped in a bit with a push rod.
alternately, on a tubeless with a stem that leaks a bit.. those slime sealants, added to the tire, then rolled around to coat the base of the stem, usually seal em up..
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Adams Conveyor (A51039)
Adams Conveyor...
2018 Ford F-150 (A51039)
2018 Ford F-150...
