Remote ON/OFF PTO
   / Remote ON/OFF PTO #1
Tunin
Medjugorje
B2410 Kubota, Antonio Carraro SRH9800 and SRX8400
Hello, I was wondering has anybody wired a remote on/off PTO on a Kubota tractor? During our grape harvest, when unloading grapes from the grapes trailer (auger/pump, pto driven) in to our destemmer, sometimes I am alone running it all, it would be really helpful.
When the destemmer is full I need to run in to the tractor to shut the pto off, when the destemmer catches up, I need to turn it back ON. I need to stand next to the destemmer because I need to watch for any hard (scissors, rocks..) objects in the grapes.
I did some research, I think I will need a remote and a remote/relay, found some cheap ones running on 533 MHZ and a DPDT 12V relay to piggy back the priginal PTO switch and an isolation switch to kill power to it when I do not need this option.
Any input would be greatly appreciated.
   / Remote ON/OFF PTO #2
Anything is possible if you have the time, money and motivation to do it.
If you have employees and live in a place like Canada with labour laws then be prepared for big fines and jail time if a worker/bystander gets injured or killed because your automation didn't use appropriate safeties and guarding to protect workers and bystanders from injury due to unintended activation of your device.
   / Remote ON/OFF PTO
He hee, Luckily I do not live in Canada/USA... to many lawsuits, regulations there.
   / Remote ON/OFF PTO #4
I forget which models but Massey Ferguson had the feature from the factory.
The tractors were bigger than what I needed so I don't know how it worked out or if it is still available.
I saw it as a potential death trap.
You know some dummy was going to use it while reaching over too far...
   / Remote ON/OFF PTO #5
Any of the various electrically operated PTO's should be operatable with a remote switch as you desire too.
They are some commercial setups available.
Here is a link to one of them;
RcFarmArm Wireless Tractor Controller
   / Remote ON/OFF PTO #6
For safety reasons, I don't recommend doing it, but some newer Kubota tractors use an electric clutch on the PTO. If so, it should be simple to tap the circuit with an RF or Bluetooth remote relay. If range isn't an issue, more than 30' or so, I would use Bluetooth since there is less chance of unwanted activation from RF interference.
This one uses your smartphone as the transmitter:
https://www.aliexpress.us/item/3256...pGJRdWlJSyRoC4TkQAvD_BwE&gatewayAdapt=glo2usa
Or this one which uses separate transmitters:
   / Remote ON/OFF PTO
I know it is something that would be a safety issue but everything working the fields is. Accidents happen no matter what, just as long as one is not dumb.
Yes, this little Kubota has an Push turn latch button, three wires, switching the voltage from the common to ether one of the pins. I am thinking I can do this with a SPDT relay and a relay remote. I only need this a few days a year, I might not even use it is there is someone around to hold the hose and watch the destemmer as I control the PTO...
Thank you all.
   / Remote ON/OFF PTO #8
Thank you all.
May be safer and easier to run parallel wiring to a push turn latch button mounted on the grape trailer. I definitely would not want a cellphone app for it.
   / Remote ON/OFF PTO
I was thinking of the parallel extension cord type of a switch, installed somewhere, I wanted to buy a Kubota switch for this, I almost fainted, 190 euros for the switch. I researched some other, those switches are pricey, cheaper way was the remote way...
I was also thinking of making an extension cable, 5-6 m, 3 Pin Deutsch connector... I do not have tools for these connectors and they are hard to get here.
I did this with my pumps, three phase and two phase in my basement, I could not bealive the price of ready made commercial remotes for three phase pumps. I built mine from junk I found around the garage.
   / Remote ON/OFF PTO #11
Wow, I was thinking oem switch too, no way I’d pay that. Just a regular e-stop should work. Of course, I have 0 clue which store to send you to.
   / Remote ON/OFF PTO #12
If you could wire up a 'dead man' type switch that would need to be held, it might be safer.. Dunno how that would work for your setup and work needed though.
   / Remote ON/OFF PTO #13
I would mount a switch on the grapes trailer and hard wire it to a plug on the tractor. I would further make the PTO switch on the tractor only work when the remote switch on the grape trailer is not connected. Then there is only one place to turn the PTO on, Either the tractor or the trailer. Not knowing how the kubota is wired, so I can’t help more than that.
   / Remote ON/OFF PTO #14
Wire the tractor and the remote switches in series. They have to be both on for things to activate and consequently, the pump can be stopped with either of them. Quite safe; unlike parallel wiring you don´t get surprises because off is always off. For the plug you might take a professional metal 3-prong microphone chassis and plug that do have a screw ring to hold it in place; those are used by bands and singers, are very sturdy and cost somewhere under 10 Euros. If the remote is not connected, a replacement plug must be hardwired through internally, otherwise the tractor switch will not do anything. For safety go for wiring; you can't trust technically simple and insecure things like bluetooth or anything wireless.
   / Remote ON/OFF PTO
Thank you guys, much appreciate the input.i ordered some 3 pin Deutsch pigtails, they should plug right in when I unplug the original switch, it is easily removed… I will hardwire the wire in to the trailers, we have two. Use the original switch by making a easy removing mount.
I would not want the switch to be exposed to the weather while in storage, it has a original tarp but still.
Some photos of the trailers…
   / Remote ON/OFF PTO
Hi guys, I did it, it works like a charm, I was going to do it via a cable, a switch on the grapes trailer but I went back to the original plan, remote control 433Mhz, simpler, cheaper, I live in an area where I am probably the only one in miles that uses anything on this frequency...
I will only use this one ca year, for the harvest, I added two safety switches, one keyed and one that powers the relay, both need to be turned ON for the remote to work.
I was going to post a video here but no go for videos on this forum...
Anyhow, thank you all for any and all input.
Regards,
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
500BBL WHEELED...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
