remote hydrolic
/ remote hydrolic #1
boxorox
jax fl
shibaura s1500/kuboto bx2200/
where should I look for a remote hydrolic out put on my shibaura s1500 fourcylinder or where can I tap into to to .
/ remote hydrolic #2
What do you have for hyd now. Pump, 3pt. Anything else?
Do you have a loader, and if so, does the loader valve have a PB port?
/ remote hydrolic
no loader but it has bolt holes in trans for loader the hydrro pump is in front of engine with pipe running to rear. is there a way to split the pipe .
/ remote hydrolic #4
If you have bolts that cover hyd ports, then use the pressure and return ports for loader , remotes or whatever.
To check for pressure, take a 3000 psi hyd gage and adapt it to the bolt holes and check the pressure.
If you have an external pipe, you can cut and install fittings to install a loader valve.
Be sure and get a loader valve with PB.
You could also do the remotes at the same time for T-N-T, etc.
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
HYDRAULIC FLUID TANK (A68842)
HYDRAULIC FLUID...
PALLET OF WOODEN STAKES (A68842)
PALLET OF WOODEN...
2023 Landmaster L5 (A64912)
2023 Landmaster L5...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A66736)
2022 East...
Trump 2028 Metal Decorative Sign (A66738)
Trump 2028 Metal...
