remote hydrolic
/ remote hydrolic #1
boxorox
jax fl
shibaura s1500/kuboto bx2200/
where should I look for a remote hydrolic out put on my shibaura s1500 fourcylinder or where can I tap into to to .
/ remote hydrolic #2
What do you have for hyd now. Pump, 3pt. Anything else?
Do you have a loader, and if so, does the loader valve have a PB port?
/ remote hydrolic
no loader but it has bolt holes in trans for loader the hydrro pump is in front of engine with pipe running to rear. is there a way to split the pipe .
/ remote hydrolic #4
If you have bolts that cover hyd ports, then use the pressure and return ports for loader , remotes or whatever.
To check for pressure, take a 3000 psi hyd gage and adapt it to the bolt holes and check the pressure.
If you have an external pipe, you can cut and install fittings to install a loader valve.
Be sure and get a loader valve with PB.
You could also do the remotes at the same time for T-N-T, etc.
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
2016 Jeep Patriot Sport SUV. (A64557)
2016 Jeep Patriot...
JOHN DEERE 5510 TRACTOR (A64278)
JOHN DEERE 5510...
2025 SDLANCH Rachet Tie-Down Strap (A64194)
2025 SDLANCH...
RKI 3,200lb. Crane Boom (A64194)
RKI 3,200lb. Crane...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
