Remote hydraulic size for 2008 M9540
   / Remote hydraulic size for 2008 M9540 #11
Any pictures? With odd mm dimensions you list....that sounds sae. 12.7mm is 1/2" and 9.5 would be 3/8". But where were those measurements taken from?
A given size NPT will appear to ha e much larger threads than the same nominal size orb or jic
It wouldn't be odd dimensions as I stated. I only stated those dimensions because that is conversion from 3/8" and 1/2". I'm thinking 12mm, because it seemed closed to 1/2".
   / Remote hydraulic size for 2008 M9540 #13
This is dimensions I found by Googling the PN 3C001-82030. .654” OD x 18TPI Male Thread
I believe .654" OD is slightly smaller than 3/8" NPT. The female threads on my remotes are definitely bigger than 3/8" NPT and smaller than 1/2" NPT. Unless, the fitting I ordered really wasn't 3/8" X 1/2". Either way, I'm glad I'm back in business.
   / Remote hydraulic size for 2008 M9540 #15
Why do you think it couldn't be 3/8npt??? You never tried that.
What you did say that you tried was the 3/8 orb.
Like I said, 3/8 orb is gonna be alot smaller than 3/8 npt.
3/8 npt is gonna fall somewhere between the 1/2 npt and 3/8 orb fitting that you tried.
And I also say again....pics help. Cause at this point, I think it's clear you don't have a good understanding of orb,npt,jic, etc. And many of us on here can tell what it is just by looking at a pic. At least the male threads for sure. Might not know the size without a measurement, but type...certainly
The fitting that broke off was an orb. I'm back at work for a couple weeks so I can't take off the fitting and lost a picture.
   / Remote hydraulic size for 2008 M9540 #17
If the fitting was an ORB fitting, and you tried a 3/8 ORB fitting, and it was too small. Then a 1/2" NPT was too large.......then it was probably a 1/2" ORB
Maybe so, I assumed orb and NPT were the same od, but the orb wasn't tapered and is shorter.
   / Remote hydraulic size for 2008 M9540 #19
No. ORB fittings are smaller thread than pipe fittings
A size smaller NPT fitting is usually pretty close to the same size as ORB. IE.....3/8NPT and 1/2orb are close. 1/4 pipe and 3/8 orb
the 3/8 orb fitting you tried is ~ .560" OD
The 1/2" NPT you tried is ~.840" OD
A 1/2 orb fitting would have been ~.750
and 3/8 NPT ~.680
here is a good reference. I think just what you need:thumbsup:
https://www.discounthydraulichose.com/v/vspfiles/downloadables/thread_guide.pdf
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
New Calf Hut (A50515)
IH 810-10 Pick Up Head (A50514)
IH 810-10 Pick Up...
2008 Ford F-250 Knapheide Service Truck (A50323)
2008 Ford F-250...
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
2023 GTC 39 END DUMP TRAILER (A50854)
2023 GTC 39 END...
