Remote hydraulic size for 2008 M9540
   / Remote hydraulic size for 2008 M9540 #11
Any pictures? With odd mm dimensions you list....that sounds sae. 12.7mm is 1/2" and 9.5 would be 3/8". But where were those measurements taken from?
A given size NPT will appear to ha e much larger threads than the same nominal size orb or jic
It wouldn't be odd dimensions as I stated. I only stated those dimensions because that is conversion from 3/8" and 1/2". I'm thinking 12mm, because it seemed closed to 1/2".
   / Remote hydraulic size for 2008 M9540 #13
This is dimensions I found by Googling the PN 3C001-82030. .654” OD x 18TPI Male Thread
I believe .654" OD is slightly smaller than 3/8" NPT. The female threads on my remotes are definitely bigger than 3/8" NPT and smaller than 1/2" NPT. Unless, the fitting I ordered really wasn't 3/8" X 1/2". Either way, I'm glad I'm back in business.
   / Remote hydraulic size for 2008 M9540 #15
Why do you think it couldn't be 3/8npt??? You never tried that.
What you did say that you tried was the 3/8 orb.
Like I said, 3/8 orb is gonna be alot smaller than 3/8 npt.
3/8 npt is gonna fall somewhere between the 1/2 npt and 3/8 orb fitting that you tried.
And I also say again....pics help. Cause at this point, I think it's clear you don't have a good understanding of orb,npt,jic, etc. And many of us on here can tell what it is just by looking at a pic. At least the male threads for sure. Might not know the size without a measurement, but type...certainly
The fitting that broke off was an orb. I'm back at work for a couple weeks so I can't take off the fitting and lost a picture.
   / Remote hydraulic size for 2008 M9540 #17
If the fitting was an ORB fitting, and you tried a 3/8 ORB fitting, and it was too small. Then a 1/2" NPT was too large.......then it was probably a 1/2" ORB
Maybe so, I assumed orb and NPT were the same od, but the orb wasn't tapered and is shorter.
   / Remote hydraulic size for 2008 M9540 #19
No. ORB fittings are smaller thread than pipe fittings
A size smaller NPT fitting is usually pretty close to the same size as ORB. IE.....3/8NPT and 1/2orb are close. 1/4 pipe and 3/8 orb
the 3/8 orb fitting you tried is ~ .560" OD
The 1/2" NPT you tried is ~.840" OD
A 1/2 orb fitting would have been ~.750
and 3/8 NPT ~.680
here is a good reference. I think just what you need:thumbsup:
https://www.discounthydraulichose.com/v/vspfiles/downloadables/thread_guide.pdf
(2) 500 GAL WATER TANKS (A50854)
(2) 500 GAL WATER...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
2008 SHOP BUILT  STEEL TANKER TRAILER (A50854)
2008 SHOP BUILT...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
John Deere 637 Disk (A50514)
John Deere 637...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
