Relieving Hydraulic Pressure - Best Method?
/ Relieving Hydraulic Pressure - Best Method? #1
Osconda
Texas, Williamson County (aka Texas Hill Country)
New Holland TC55DA, delivered 05/25/2005
When I bought my tractor I also got a root grapple for my loader. Picture of it here: http://www.rootgrapple.com/GRAPP40.jpg
It's a piece of cake to quick detach my loader bucket and attach the root grapple but the hydraulics is a different story. Here's the details....
When I received the grapple it came with a set of hoses already attached. These hoses have threaded fittings where they connect to the frame of the grapple and the other end of the hoses had a quick disconnect fitting. In order to get my rear hydraulics connected to the grapple, I went down to a local hydraulic shop and had two extension hoses made to length with quick disconnect fittings that matched the existing hoses that came with the grapple. I picked up a set of quick disconnect fittings at my dealer that match my tractor's rear remotes and installed them on the other end of the "extension" hoses.
The quick disconnect fittings that attach to the tractor have a small bump on the end but the fittings that came on the grapple are flat. More on this later.
If I'm switching from the root grapple to the material bucket I don't have any trouble taking the hydraulic fittings apart. Switching these two takes about 3 minutes.
If I'm switching from the material bucket to the root grapple, somehow there is some built up pressure left in the cylinders and there is no way to connect the grapple hoses to the tractor hoses without taking a wrench and loosening the threaded connections. It doesn't seem to matter whether the cylinders are retracted or not. There is no way to relieve pressure on the flat quick disconnect fittings on the grapple, like you can on the tractor fittings.
I was wondering if there was some kind of valve I could put between the threaded fittings and the quick disconnect fittings so I could just quickly open and close to relieve the pressue. The valve would have to be able to handle the 2500 PSI working pressure. Or perhaps somebody has some other creative idea on how to solve my problem.
/ Relieving Hydraulic Pressure - Best Method? #2
Lots of people report this with loaders and QD's.. they simply set it down.. kill the tractor.. then run the spool controll all around till the hyd pressure is released.
The other non-scientific method was discussed as poppint the tip o fthe qd with a wrench to make it squirt some of that pressure out.
Soundguy
/ Relieving Hydraulic Pressure - Best Method? #3
Like Soundguy said, use the "other non-scientific method". If you do though, be sure to wrap a rag around the end of the hose. Keeps things clean but most importantly, protects you from that stream of high pressure hydraulic fluid /forums/images/graemlins/smile.gif
</font><font color="blue" class="small">( Lots of people report this with loaders and QD's.. they simply set it down.. kill the tractor.. then run the spool controll all around till the hyd pressure is released.
Soundguy )</font>
There is no tip on the end of the quick couplers, they are flat. The hydraulic remote only has an up and down movement and I have tried working this before I disconnect the grapple but it doesn't make a difference.
/ Relieving Hydraulic Pressure - Best Method? #5
Can you take a picture of the disconnects and possibly post it here for further advice?
Before I disconnect our grapple I slightly open it (helps so the pressure doesn't build against the bucket) then pull the disconnects apart. Hooking it back up is simple if I follow my own instructions.
/ Relieving Hydraulic Pressure - Best Method? #6
Do your couplers look like the one in the attached picture?
If so then press in on the male end's flat surface to relieve pressure in the hose.
Also make sure you are putting these flat male couplers into female QD's that are specially designed for them. The ball couplers and these drybreak flat ones are not always compatible.
No the couplers don't look like the picture. I'll take a picture and post it later. Also, the couplers do match up correctly and I don't have any trouble connecting them, once the pressure is relieved.
/ Relieving Hydraulic Pressure - Best Method? #8
I've got the same problem with my flat faced couplers on a tracked loader. I've been going back and forth between tree shear and grapple and it takes about 15 minutes/per change. I'm hoping its only a damaged coupler from an incident involving too short of a hose on a new attachment. In the meantime, I made a device to depress both couplers on each side of the connections. I also made a handle to get a better grip on the hose connectors.
I don't think it takes very much external force on the grapple to develop enough pressure that you can't overcome it with hand force. Like the grapple arms settling in the dirt after you disconnect it. Someone else mentioned sitting out in the sun could cause it. Pineridge's trick of leaving it open may work because his grapple arm is light but it would be the wrong thing to do on mine.
Also, did you check your manual about how to relieve residual pressure on the loader side?
John
</font><font color="blue" class="small">( I've got the same problem with my flat faced couplers on a tracked loader. I've been going back and forth between tree shear and grapple and it takes about 15 minutes/per change. I'm hoping its only a damaged coupler from an incident involving too short of a hose on a new attachment. In the meantime, I made a device to depress both couplers on each side of the connections. I also made a handle to get a better grip on the hose connectors.
John )</font>
The grapple was designed with a skid steer compatible plate so I guess the flat faced couplers are common to a skid steer loader.
I'm thinking that the two grapple arms are heavy enough (3/8" steel) to put back pressure on the cylinders. It's impossible to pull back on both grapples and then try to make the connection (requires 4 hands). I make it a practice to keep the cylinders retracted( grapple open) so the cylinders aren't exposed to the weather if I don't use if for an extended period.
JMC, I'd like to see a picture of the gizmo you made to help you make the connection.
I accidently disconnected the grapple once with it closed(cylinders extended) and I had to let a lot of fluid out to make the connection.
I've got 60 hrs. on my tractor now and probably half of those have been using the root grapple. It's a great tool but it sure would be nice if the couplers really were "quick".
/ Relieving Hydraulic Pressure - Best Method? #12
If you want to go thru the trouble and expense you can make a loopback hose that will connect the implement hoses back to the same cylinder on the attachment when it is not in use. Just use appropriate quck couplers on a short piece of hose. Also keeps the connectors clean.
Ben
The residual back pressure is there immediately after removing the implement hoses. I don't see how it would be possible to connect the loop back hose, because of the back pressure. If I could, then I should be able to connect the regular hoses.
Am I understanding this right? Maybe I'm not understanding the concept of a loop back hose.
/ Relieving Hydraulic Pressure - Best Method? #14
I had the exact same problem with my grapple....
I solved it the following way:
1. Always drop the grapple teeth before disconnecting... that way gravity won't drop them for me, creating pressure in the grapple system.
2. Shut off the tractor so the pump isn't pushing fluid.
3. Operate the grapple control in both directions to equalize and relieve any pressure built up on either side of the control.
4. Disconnect the grapple and grapple hoses from the tractor.
5. Plug the grapple hoses into each other. Keeps them clean, and equalizes any additional pressure created by the sun warming up the grapple.
6. When reconnecting, do steps 2 and 3 once I have the grapple installed on the tractor but before I connect the hoses from the grapple to the tractor.
I've been following this procedure for a year now and have not had a problem since, *unless* I forget a step, then I have to get out my big flat-head screwdriver and open the hose fitting with a sharp tap on the driver with a hammer. It's all about relieving the pressure from the system *before* you disconnect the hoses.
By the way, I use the same procedure with my BH. I really hate it when I forget a step with the BH, because it means I have to get under the tractor (usually in the mud) and resort to the hammer and screwdriver... ...Grrrrr! /forums/images/graemlins/mad.gif At least my wife gets a laugh out of it. /forums/images/graemlins/grin.gif
Thanks BadDog! Great Advice! I don't think I've ever tried that exact sequence. I'll print this out and give it a try. I'm sure it'll work. Glad somebody already figured this out.
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Relieving Hydraulic Pressure - Best Method? #16
Are those Parker fittings? They look like the same (similar) style I just used to plumb my tractor. I've had a bunch of problems re-connecting my dump wagon as well. I attached a photo of the lines I ran to the front. What has finally been working for me (knock on wood) is to:
1. Shut off the tractor.
2. Move the loader joystick in every direction so every thing is neutral.
3. Cycle each spool (3 of them) on my auxiliary valve.
If I do this faithfully, it appears to work. If I miss a step, it's curse time!
/ Relieving Hydraulic Pressure - Best Method? #17
My grapple is all Parker fittings...
/ Relieving Hydraulic Pressure - Best Method? #18
Those are drybreak or non-spill couplers very similar to, but of a different manufacturer than, the pictures of the Snap-Tite ones I posted earlier.
DMF's couplers look like Parker FF series. You can read all about the Parker Fx series of non-spill couplers starting on page 23 HERE.
You should be able to depress the flat faces of the couplers to relieve pressure but it may take some uumph on your part.
I believe my couplers are the FE type according to the description and by comparing my pics to the .pdf linked file from Parker's.
DMF,
Sounds like you're saying you have three sets of rear remotes with those two hoses going to one set. If so, I don't understand the logic behind having to mess with the loader joystick. Isn't the loader independent of the rear remotes? I'll admit, I don't know much about hydraulics. /forums/images/graemlins/confused.gif
2025 Pabreak Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
2017 Terex RL4 S/A Towable Light Tower (A60352)
2017 Terex RL4 S/A...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
