Oil & Fuel Regular oil or synthetic
   / Regular oil or synthetic #11
LOL!! Your right on that. I spent a year in Minot, ND and the first week I was there it was -43degrees. Cars had to have engine tank heaters and light bulbs beside the battery and even then the engines cranked very, very slow and with prayer would sometimes start. Course the wind never stopped blowing so with chill factor it was probably a hundred below zero which doesn't affect metal but sure did/does skin. I would probably use synthetic oil in the higher Northern reaches of the country. If it gets below zero in Ky, and it some times does, we stay in unless we have to get out.:D
I'd just love to walk into a Kubota dealership in Kentucky and ask for a block heater and a battery blanket, yuh know just to see the expressions on their faces.:D
   / Regular oil or synthetic #12
that's a good one ;-) but I don't care what color you have my manufacture recommends 200 hours changes which is fine during normal usage but when conditions get extreme like excessive rocking fields and mowing hay with disk mower all day I change my oil more frequently $40,000 investment versus a $80 change by the way I run synthetic year-round doesn't use a bit of oil between changes take care
   / Regular oil or synthetic #13
Keep changing at every 10 or 50 hours and I'm sure every sample will come back fine. I'd say you can keep that up and save the cost of sending off samples.
Your kidding aren't you?
The first oil is ran to 50 to get the engine broken in correctly and my understanding is that it's a different oil made for that purpose. I've heard this alot but do not have proof but again I've heard it about cars, trucks and tractors that they have "break in oil" to be used for the first number of specified hours.
No kidding, I like to drain oil on new units earlier than normal. I ran tractor very hard right off the lot after I got it bush hogging 18 acres. Plus, oil that came in it was 10w-30, wanted something heavier. When I got to 50 hours it was time to do rest of service, so I just changed oil again (including SUDT) before winter. Remember, some people keep equipment for a LONG time, like me, so I take extra care of it. I think you get a new piece of equipment like what, every 200 hours or so? :) Philip
   / Regular oil or synthetic #14
At no time will synthetic be bad for your engine. Only the cost is the drawback. If you live in a cold climate it will pay for itself. As far as extending oil changes I would maybe a little. Of course I think most manufacturers tend to stretch that too far anyway. Depends a lot on the use. Most of the small tractors get short intermittent use which is hard on the oil.:)
   / Regular oil or synthetic #15
Your still kidding aren't you? 200 hours!!!:) I had one that had, I think, 105 or maybe 130 hours. A B7800 that I had owned for 3 years.
I still service every one of mine like I'm going to keep them forever even though that hasn't happened.... yet..... but I expect it to one day.....well....it could happen one day.:D OK it's probably not ever going to happen but I'm still treating them like it is. That's why people wait on my trade ins, cars, trucks and tractors.:)
I stuck to the cars and truck oil change every 3000 miles for years and years. Even after some manufacturers went up to the 7500 recommended change but I have finally moved out to 4000 to 4500 some times unless the time is pretty long and then I'll still do the 3000. My mind says follow the manual on cars and trucks but my heart won't let me. $22 for oil and filter change on vehicles, I'll do a bit early.
   / Regular oil or synthetic #16
Remember some people may put 200 hours on a tractor in a couple of months. Kubota I think recomends 100 hour oil changes.
   / Regular oil or synthetic #17
I think you need to look at your owners manual.:)
   / Regular oil or synthetic #18
Kubota does indeed recommend 100 hour oil changes and filters every two hundred hours, I change filters when I change oil, always have and always will. Oil filter costs less than a six pack of beer so it's no big deal.
   / Regular oil or synthetic #19
My wife is running CaseIH No. 1 Diesel oil 15W40 in everything but the gas tractors. It's been fine for all these years so we see no need in changing.
   / Regular oil or synthetic #20
I will throw my two cents worth in here. We have tractors made in the 50's and 60's on up and have never used anything other than a good petroleum base oil. My brother started out as a tractor mechanic then went to cars then industrial stuff. He has raced cars and keeps vehicles a LONG time. He also raced cars for a few years. We all tried synthetic oil several years ago and after tearing a couple of engines down, decided it really wasn't worth the money. My other brother who lived in California also does all of his own mechanical work and his results mirror ours.
I live in Missouri, so extreme cold is not a problem and like John, if I lived some where to the far north, I probably would go with a synthetic. My personal experiences has been that for my applications a good petroleum base oil works as well as a synthetic. I don't even know anyone who uses a synthetic oil.
Synthetic certainly isn't going to hurt anything and I am sure it has advantages in extreme conditions.
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55315)
2003 International...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55315)
2023 New Holland...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
40006 (A55788)
40006 (A55788)
