regenerative hydraulics for a log splitter?
   / regenerative hydraulics for a log splitter? #1
Cord
Veteran Member
Richfield, Wi
Resident Architect
Do any members know how to design a regenerative hydraulic system? It would need to be pressure based system which would automatically unload once the cylinder encountered the work. The unload pressure would be 2-300 psi. The thing that is tripping me up is that the regenerative system can not be based in the control valve, it needs to a external valve. Things like hose routing and part numbers would be needed.
This is the autocycle valve that I was planning on using. You can find the plumbing diagram on page 6. http://www.princehyd.com/LinkClick.aspx?link=products/valves/AutoCycleManual.pdf
   / regenerative hydraulics for a log splitter? #2
It's an interesting idea, but would would like to know more about how you want the splitter to work in its cycle with this.
Well, that could be a problem. I don't know enough about hydraulic design to know if there will be a problem or not. Basically, my desire is to have the ram come forward as a regenerative circuit until it starts to build pressure. Then a pressure sensitive check valve will close and the circuit will function normally. I know that this is very do-able for a standard log splitter. I don't know how it will work with the autocyle valve. Even for a standard log splitter, I don't know what the circuiting or components are, I just know that it's do-able.
   / regenerative hydraulics for a log splitter? #4
Unless I misunderstand the idea..
Fast ram extension till it hits resistance?
Two stage pump.
Haldex two stage pump
A regenerative circuit ties the piston side of the ram together with the rod side so the actual piston speed is greater than what the pump output is. Some loader valves have a regenerative circuit on the bucket dump. This lets the bucket roll very quickly.
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
