Refurbising splitting wedges
   / Refurbising splitting wedges #1
Paul Thornton
Mirror Lake, NH
Kubota L2800 HST w/ FEL
Have several splitting wedges which have been beaten to the point of being useless. I was thinking of putting a cutting wheel on my grinder and trimming them. Has any one any ideas or suggestions? L2800 w/FEL - 72" Land Pride rake
   / Refurbising splitting wedges #2
I've ground off the mess before - then ran some stick welds around them.
Worked fine - have at it in my opinion :)
   / Refurbising splitting wedges #3
They should never be let go to that point. They should have been dressed when they started to mushroom.
They should be cut/ground back as normal maintenance.
Thanks for the replies, I'll have at them with the grinder. I inherited these from my FIL. I have two more that look just the same, couldn't bring myself to throw them out.
   / Refurbising splitting wedges #5
I'd put a thin cutoff wheel in your handgrinder and cut from the backside to take most of that off without generating any heat. Then you could dress it up on a grinding wheel.
   / Refurbising splitting wedges #6
2X
Exactly what I have done.
   / Refurbising splitting wedges #7
I found a wedge that looked like yours. Used a cutting torch to trim the mushroomed edges. Easy and quick.
   / Refurbising splitting wedges #8
After you grind them into shape paint them orange so you will be able to find them in the woods.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2022 JOHN DEERE 6120M LOT NUMBER 192 (A53084)
2022 JOHN DEERE...
