Refurbising splitting wedges
/ Refurbising splitting wedges #1
Paul Thornton
Gold Member
Mirror Lake, NH
Kubota L2800 HST w/ FEL
Have several splitting wedges which have been beaten to the point of being useless. I was thinking of putting a cutting wheel on my grinder and trimming them. Has any one any ideas or suggestions? L2800 w/FEL - 72" Land Pride rake
/ Refurbising splitting wedges #3
They should never be let go to that point. They should have been dressed when they started to mushroom.
They should be cut/ground back as normal maintenance.
Thanks for the replies, I'll have at them with the grinder. I inherited these from my FIL. I have two more that look just the same, couldn't bring myself to throw them out.
/ Refurbising splitting wedges #5
I'd put a thin cutoff wheel in your handgrinder and cut from the backside to take most of that off without generating any heat. Then you could dress it up on a grinding wheel.
/ Refurbising splitting wedges #6
2X
Exactly what I have done.
/ Refurbising splitting wedges #7
I found a wedge that looked like yours. Used a cutting torch to trim the mushroomed edges. Easy and quick.
/ Refurbising splitting wedges #8
After you grind them into shape paint them orange so you will be able to find them in the woods.
2001 FREIGHTLINER FL80 6X4 T/A VACUUM TRUCK (A67148)
2001 FREIGHTLINER...
PALLET OF METAL STOVE PIPES (A64278)
PALLET OF METAL...
JOHN DEERE QUICK ATTACH PALLET FORKS (A64278)
JOHN DEERE QUICK...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
KUBOTA TE6583T - 6 BASKET HAY TEDDER (A64278)
KUBOTA TE6583T - 6...
