reflective tape
/ reflective tape #11
In Nova Scotia I believe that fifty percent of the trailer side must red/white reflective tape installed.:D
US DOT requires 50% coverage along the length of each side, the full width across the rear and silver right angles at the upper corners retrofitted to all commercial trailers still in service.
After 1997 they require the same silver right angles on the top back of a tractor cab and a strip across either the back of the cab -or- across the top of each mud flap...Now that most used tractors are in this age period, the mudflap red/silver is usually missing unless the tractor is in use w/ a large carrier.
The DOT allowed carriers who had retro reflective sheeting in their logo designs to use them to retirement while adding red/silver to the new purchases.
/ reflective tape #12
Thanks for all the information Wis Bang. The trailer sides are covered but the backside may be a little exposed.
/ reflective tape #13
Retro Reflective Tape is designed to give a larger reflection from an angle, I think 30degrees, than from directly @ 90 degrees and was designed to help a motorist see a trailer without it's lights parked on the shoulder of the highway.
If you watch you will notice trailers parked inside construction sites reflecting your headlights even when well off the road.
I take a section of red and place small sections on car/truck door edges so they light up as you open the door at night. I have some on my hitch haul too!
/ reflective tape #14
I added it to the rear and sides of our trailer even though it met DOT requirements and them forgot about it. Didn't see what it looked like at night until the bearing failure last trip north. Then saw it in my trucks headlights on the wrecker. The tape at eye level is a bit bright if kept clean.:cool:
/ reflective tape #15
If you note standard lighting practices, red is never in front, and yellow is very often on sides with red always at the rear.
That being noted, it would seem that yellow would be an appropriate tape on sides.
I seem to recall yellow and black stripes used on sides of some equipment.
My tractor looks like a Xmas tree under the glare of high beams.
Loader arms have the super white on sides, bucket the yellow/black on sides and my snowblower bank cutter bars are red/white.
Back of my tractor sports strips of red 3M DOT tape as well as the triangle SMV!
I also have a yellow strobe on the roof.
As you can gather I have had a few close calls cleaning my driveway.
Just too many idiots out there.
I'd be backing out blowing snow, and idiots would step on the gas to pass before I completely closed the gap.
In other words a race for a 4-5 ft space. (in a snow storm yet)
To make matters worse, there are a mere 10 people that live past me on a dead end country hilly twisty road.
Since they always get up too late, they need to step on the gas to make it on time.
Wost yet, they are putting on lipstick, on the cell phone or adjusting a tie.
2004 Kubota M4900 Utility Special (A60462)
2004 Kubota M4900...
Kubota M108S (A53317)
(25) Safety Traffic Cones (A60463)
(25) Safety...
2022 CATERPILLAR 307.5 EXCAVATOR (A62129)
2022 CATERPILLAR...
MMS 750 Remote Control Lawn Mower (A60463)
MMS 750 Remote...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
