Reese hitch receiver tubing undersize
/ Reese hitch receiver tubing undersize #21
Our local yard just sells it as 2" ID square seamless. The hick way is to use seamed tubing and grind a groove in the receiver.
I had some 2" seamed I had to use as a receiver so I ground a cold chisel and cut the seam off.
/ Reese hitch receiver tubing undersize #22
Watch what kind of square steel tubing you use . Some if it is hotrolled and has seam, and some is extruded & cold drawn and is seamless. The hot rolled won't stand the pressure that the other will . I would be carefull of type I used on a hitch that was going to have some weight on it. I would go to a regular hitch dealer or camper dealer to get products to build Hitches. You are puting somones life in danger by using CHEAP products.
/ Reese hitch receiver tubing undersize #23
i used the rolled and welded heavy tubbing for my hitch and have stalled my tractor out towing with it, a jd 4310 27 hp, and had no problem with it
/ Reese hitch receiver tubing undersize #24
I tried making the female part (reciever) of a Reese hitch once. I learned that the Reese tube had no inside seam but the standard tubing I had DID have an inside seam on one side. Made it impossible to slide existing male parts in.
Also learned the hard way that the squared corners on some tubing will not slide into the Reese reciever. It has to be the rounded corner tubing.
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2020 DRAGON ESP...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60430)
2018 WANCO WTSV...
2021 Takeuchi TL6R Compact Track Loader Skid Steer (A59228)
2021 Takeuchi TL6R...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2018 CATERPILLAR...
