Redneck PHD / Tree Planter
/ Redneck PHD / Tree Planter #1
Champy
Indiana
John Deere 990
Well, I've got 1000 evergreen seedlings to plant next week and as luck has it I blew out my shoulder (don't ask - stupid human trick backfired). So I created a backwoods post hole digger to help with the planting.
Took some scrap metal; chains; eye bolts; bungee cords; and my hand held 2 stroke auger. The concept was to make a cheap boom pole like device on my 3PH that would hold up the auger to use making the holes for the transplants (in a disc'd / plowed field) behind the tractor. I'll let you know how it works in a few week maybe....
Here's some pics. I'll probably get some mail from the safety police, so fire away.
/ Redneck PHD / Tree Planter #2
Well, the safety police are on that one because it looks dangerous. Having nearly killed myself six times over 60 years I would like to suggest a different approach.
Since the field is already plowed and disked, why not just get a 3 pt hitch cultivator and put a "shovel" on it. I did this before and used a 12 or 15 inch cultivator "shovel" I bought from a mail order farm store for $15. Put it on my one row cultivator. Made a deep--8-10 inch-- groove in my prepared soil and had some high school kids plant the trees and stomp dirt on top. Didn't lose a seedling.
A relative of mine does a lot of trees and recently tried this approach and liked it.
/ Redneck PHD / Tree Planter #3
I don't like those PHDs. I injured myself using one of these when it hit a rock. I tweaked my back and shoulder. IMO, I'd get one that fits on the tractor...save yourself!
/ Redneck PHD / Tree Planter #4
1000 trees? that's it??
Shovel and a bucket. You can do 1000 trees in 1 long day.
If that's you in the pictures, then I'm 2x your age and 3-4x more out of shape and have done it many times. Just buy a long skinny shovel and jump on it twice, rock it back and forth, pull it out, put the tree in, stomp the ground closed and repeat 999 times. You can do 2 trees a minute for as long as you have trees in your bucket.
/ Redneck PHD / Tree Planter #5
Wear a helmet... When that PHD digs in, it is going to load up those bungies and if they let go or apply too much force, that boom may come down on your head. How deep are you planting these seedlings that they need a PHD anyway? Standard method is as described. Jump Jump, Wiggle Wiggle, Place seedling, stomp and move on to the next one...
Actually I surveyed a number of Xmas tree farmers and they recommended using the hand-held power auger approach. Mixes up the soil and provides for better backfill / no air pockets. They also said to avoid using a 3PH PHD because you cannot get the tractor aligned right for every tree or its difficult to use on side hills.
Last year I ran a subsoiler down the rows and then we used a dibble bar to plant them all by hand. Wasn't too bad - my 15 yr old (in the picture) did all the digging. The concern raised by my xmas tree advisors was that a shovel or dibble bar makes a single cut that can root bound the seedlings or leave air pockets, whereas the auger approach allows for the roots to spread out.....although last year I had less than 10% failures.
I'll update on how this works......I may just end up running the auger without the harness approach. If all else fails its back to the dibble bar / planting by hand.
PS - Jon Bud......thats my 15yr old in the picture not me. I'm 50 now and paying for years of racing motorcycles; baseball; skydiving; etc....with a bad back & knees....hence the auger hanging harness idea.
/ Redneck PHD / Tree Planter #8
How about hose clamping a " torque rod " (bar or pipe) to one of the handel grips. It would extend out towards the boom pole, then when it twists too far it will hit the boom pole and save your shoulder?
PS, Those skating acc's in the background have anything to do with your injury?:)
/ Redneck PHD / Tree Planter #9
did you look into a mechanical tree planter?
In Iowa, you can go to the State Forestry office, USDA ag office;DNR Forestry Division, Pheasants Forever, Natl Turkey Federation etc. and either use (no Chge) or rent.
You need a 3 pt tractor and another live body. One drives, the other sits on the seat on the planter. The planter slits/furrows the soil, you drop in your seedlings, the planter real wheels "crimp" the soil around the seedlings
you can plant 400 - 1000 seedlins per hour
A "hole" lot faster than PHD
example:
http://www.iowadnr.com/forestry/pdf/planting.pdf
G5009 Mechanical Tree Planters, MU Extension
/ Redneck PHD / Tree Planter #10
I wondered myself whether there was an advantage to planting with a post hole digger vs. the planting bar - so the first year on the farm, we intermixed rows of 9" PHD holes, with rows of planting bar. It took much longer with the PHD, longer to fill etc. After 5 years, absolutly no difference between the rows, no difference in height or death rate. We now plant wherever we can by planting bar, and only use the PHD if the ground is too hard.
/ Redneck PHD / Tree Planter #13
I have planted a lot of trees with a planting bar, but success is often tied to size of root system. If you plan to plant seedlings (2-0, 3-0, or 4-0 stock) their root systems are fairly meager, and you can get away with it. But take on some heavy transplants like Musser's 2-3 or 3-2 , and a planting bar can't possibly make a hole big enough. I use a top quality round pointed shovel. Turn the shovel around backwards so the end of the handle is aimed at your breastbone. In that position the blade is vertical. Move to the side (get the end of the handle off your chest), drive the blade down with your foot. Lean forward on the handle, kicking up a clod of dirt, and slide your hand down to the gooseneck. Grab the gooseneck, pull the clod up, and slide the tree roots into the hole against the back wall of the hole. Still grasping the gooseneck, pull the shovel blade out of the ground, and the clod of soil will drop right back down into the hole from whence it came. Stomp hard to eliminate air pockets. Repeat 999 times. Many Christmas tree growers (but not all) really like the auger method.
jgendr said:
You can plant 1000 in about 2 hrs with one of these LOL
Well - if you can do that many an hour, by all means stop by. I'll even buy your lunch!
/ Redneck PHD / Tree Planter #16
Well ok then, you sound a lot like me! Only I'm much younger (by 2 years!) and had different "hobbies" that have me hobbled up!
I'd still go with a shovel or dibble bar (we call them tree spuds). Actually, I'd use the 15 year old and spend time complaining about all the aches and pains while watching him work !
jb
/ Redneck PHD / Tree Planter #17
jgendr said:
Ah Yea down south that's what we use!!!!! And we plant 10's of thousands of pine saplings a year!!!!!!! You can plant 1000 in about 2 hrs with one of these LOL
8 every minute? Come on down to Washington....
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
PALLET OF MISC FLANGES/BOLTS (A68842)
PALLET OF MISC...
2007 MACK VISION (A67714)
2007 MACK VISION...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
Bomag Roller (A63689)
