Redneck at Work
/ Redneck at Work #1
jwillett
China Grove, NC / Wagener, SC
MF 1532
Been working on my $250.00 Bush Hog and my wife snapped a few pics of me inatalling a front guard I made out af some belting that was thrown away at our plant. Then a video of how I unloaded the Bush Hog off the trailer at the farm. I can't haul the tractor and Bush Hog on the trailer at the same time so I loaded it at home with the FEL and had to come up with a way to unload it. The drive in reverse and slam on the brakes was an option but really a last resort LOL. Note: I still need to finish the paint job but ran out of time.
My wife stepped on a fire ant hill while taking this but did not say a thing, that is why it is jumping around at times:
Bush Hog :: MOV07692.flv video by rubicon07 - Photobucket
Bush Hog :: MOV07693.flv video by rubicon07 - Photobucket
Plenty of help at the farm:
Bush Hog :: MOV07696.flv video by rubicon07 - Photobucket
/ Redneck at Work #2
Jim, nobody could say that you aren't resourceful to use a chainfall like that, but I am so glad that tree limb didn't break at the worst possible time. Maybe I'm being paranoid, but the postoaks at my place have big limbs that break off very easily. Watching you work under that limb kinda scared me. It sure looks like you got a bargain on that cutter and can put it back into service soon, but I hope you won't be lifting it often by using tree limbs. I'm so glad it worked out without incident.:)
/ Redneck at Work #3
Well that's one of many ways to unload,I've seen some tie/chain attachment to tree/solid object and slowly drive...but to slam on the brakes to unload...yikes.
/ Redneck at Work #4
That's the way we unload some things that are too heavy to lift. A good chain or two and sometimes some 4" logs for rollers. :)
The 'slam on the brakes in reverse' works well for dropping of drunk friends in the yard. :p
/ Redneck at Work
I was worried about the tree at first but saw it was good for the unload when no one was under it. When I was working on the front you can see that I had the weight off the tree limb by using a duct jack to hold the bush hog up. The chainfall at that point was just there as a back up.
/ Redneck at Work #7
I got the same problem, Trailer is too small to move both tractor and mower at the same time.
Can lift it high enough with the 3PH to get it on the trailer here.
Unloading it there is a tree and a chain. Chain it to a tree and just drive the trailer right out from under it.
Works good!!!
/ Redneck at Work #8
A boom pole on the tractor would have had that off quickly! I think That rubber guard is going to be U shaped on the first use -- JMHO. Good buy :D
/ Redneck at Work #9
MossRoad
"The 'slam on the brakes in reverse' works well for dropping of drunk friends in the yard."
I bet there's alot of side effects. :)
/ Redneck at Work #10
He cannot transport the tractor with boom pole and the brush hog at the same time on that trailer. Sounds like a good excuse to have two tractors, to me. ;)
/ Redneck at Work #11
Man have I helped unload a much much heavier cutter like that and we did the same...got away so if something failed we were clear. 38 years later still did not like it.
Saw a person the other day hauling a tractor and cutter that was too long for his trailer (much like this trailer) with the wheel on the cutter. He had removed the height bolt on the trailer wheel allowing him to flip the wheel up cutting the over all length by a couple of feet or so. Tailgate closed.
As to the fire ant..real pain...we had our lawn sprayed this year for $100 per acre and so far no mounds. It has been about 2 months and it amazes me to look at a smooth lawn, sort of looks odd. As professional pest people as the chemical is packaged for commercial size use and I think requires certification.
It does look like good price on mower.
/ Redneck at Work #12
I have to admit to doing this myself. Pulled engines, lifted implements to load onto my 1 ton and trailers, lifted a full sized Lincoln pipeline welder the same way. One time I rebuilt the runners on my old brush hog and used the same tree limb to do the lifting and stablizing while I welded on it. Shade tree mechanics had to have something to pull those engines out with.:D
Jay
2015 Bobcat T590 (A64126)
2015 Bobcat T590...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
2022 EZ-GO ELITE...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
