red trans fluid
/ red trans fluid #1
mah
I have noticed that sometimes tractors come from Japan with red trans fluid. Is this ok ? Is anyone familiar with this? Do certain models require something different from the jd 303 fluid? Please help.
Mike
/ red trans fluid #2
The colour of new oils is very independant to thier quality. If properly investigated you may find the Marketing Component of oil refiners does market research to determine the colour of oil pleasing to consummers.
Egon
/ red trans fluid #3
Mah,
Thats ATF. in there
automatic transmission fluid, they use that in the models with powershift transmissions.
1510 1610 ect...
/ red trans fluid
Not all powershift models come with red fluid. What type of ATF is this? What type of fluid does Yanmar recommend for powershift models?
Mike
/ red trans fluid #5
I have asked this same question before, with no results. Some models have a lable saying to use TF300 and others say TF500. There has to be a difference. BUT most of the aftermarket fluids list multiple grading. I do know that I put a universal fluid with JD303 rating in a Hinomoto and when it is cool not cold it squeels like a pig until it gets warm and when cold it wouldn't move until it got warm. With it's original fluid it didn't do it.
/ red trans fluid #6
Reed,
I think the TF is tranny fluid. the 300 and 500 are different weights, like mercon and dextron fluid are.
If your machine squeals, try a lighter weight fluid.
Correct me if im wrong
This is my 2 cents worth. /forums/images/graemlins/blush.gif
Ern.
/ red trans fluid #7
Reed, I asked this same question to a Yanmar mechanic in Japan and he replied that the 20 series and all the F series use TF500 and the other models use TF300. Basically if it has wet brakes and is a Yanmar it takes TF500. They say that the TF300 specs out as JD303, and the TF500 specs out to JD20A. Most of the time when you buy a universal hy-trans it says it meets specs for both JD standards, so go figure.
/ red trans fluid #8
That answers the question but it doesn't does it. I have noticed the dual rating, but it is confusing. Why have two ratings if one will do? Can anyone explain the difference between the two JD ratings?
/ red trans fluid
Thanks guys. I appreciate the comments but I'm still not sure what this red stuff is. If it is ATF, what type? And what is the correct fluid for powershift models? The last tractor I received with the red fluid was a YM2310. I normally replace the fluid with a JD303 equivelant universal hy-trans and have never had a problem but I would like to know if this is the wrong fluid. So, if someone has an owners manual to an American model, such as a YM226, YM276, or YM336 , and wouldn't mind posting what the Yanmar recommendations are, I would greatly appreciate it.
Thanks again,
Mike
/ red trans fluid #10
This is out of the YM336 service manual.
Caltex - RPM Tractor Hydraulic Fluid
Sun Oil - Al Tram # 303 Fluid Oil
John Deere - 303 ( J14B )
Case - Case TCH Oil ( JIC143, JIC144, or JIC145 )
Allis-Chalmers - ( ACM-7201 )
Ford - M2C4-A , M2C53-A , or M2C86A
International Harvester - Hy-Tran B-6 Fluid
Danny
/ red trans fluid #11
There is a sticker on my 186D that warns that the transmission will be slugish in the winter until it is warmed up so I guess it is normal. Some people have written here that synthetic hy/tran fluid cures the winter slugishness of the power shift transmission. Unfortunatly synthetic hy/tran fluid is kind of expensive but the change interval is long enough that if it makes the machine run better it might be worth it.
Chris
/ red trans fluid
Thanks Danny,
It looks like I'm using the right stuff.
Mike
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
1999 JOHN DEERE 344H WHEEL LOADER (A63276)
1999 JOHN DEERE...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
500 GALLON METAL FUEL TANK (A64280)
500 GALLON METAL...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
