Red to Orange
/ Red to Orange #1
gws
Platinum Member
yanmar ym1810
Well, Yesterday my trusty yanmar was sold. Was a nice tractor but a bit bigger and didnt do the mowing i had. Now the orange question. I have been looking at a couple of B1750's, One is an E the other is a DT (what is DT vs E). Both have around 500 hours on them. Both have a 60" mower and turf tires. One is 2wd and one is 4wd, both are gear shift. One list BI-stear, what is that?
Most of my work will be mowing 4 acres but I do need to bush hog a couple times a year and use a PHD once in a while.
What price range would be good for either of these tractors? Any common problem I should be on the look out for? Will either of these support a small quick attach front end loader? is the 4wd a plus or mini with a FEL on this tractor?
Thanks.
Gary
/ Red to Orange #2
<font color="blue"> (what is DT vs E </font>
DT is 4WD. E is 2WD.
Bi Steer is a differential in the front axle that speed up the outer wheel on a turn so it does not scuff the turf. B2410 still had this feature available.
If tractor has Power steering a FEL should not be a problem. 4WD is a plus with any FEL work. You may have to look for a after market FEL.
I believe the B1750 was replaced by the B2710.
Peterbilt 377 Semi-Truck (A63689)
Peterbilt 377...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
JOHN DEERE 5055E TRACTOR (A64280)
JOHN DEERE 5055E...
2022 EZ-GO ELITE...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
(1) 100 GALLON & (1) 50 GALLON OXY/ACETYLENE TANKS (A64281)
(1) 100 GALLON &...
