Red light flashes
/ Red light flashes #1
fecolbeck
2013 Branson 6640
I have a 2013 Branson 6640. I was doing some field work and hit a hole with tire. The red light on dash began to flash. I have inspected tractor and nothing obvious is wrong. Tractor runs perfectly fine but light will not go off now. Any ideas why light is flashing now? Thanks
/ Red light flashes #2
Any pictures of said light? Or a better description of said light? Otherwise we will be guessing in the wild.
If I had to guess, probably a stick pulled a wire somewhere.
/ Red light flashes #3
/ Red light flashes
Ok I got some stuff figured out. It's throwing 3204 code. Which is "towing power sensor signal error". Now a fix for that is needed. I unhooked battery and hooked back up and code is still flashing. Tractor still running great. I'm assuming a new sensor will be needed. Any advice on were this would be located would be great. Thanks
/ Red light flashes #5
Error 3204 refers to the Draft control sensor:
The draft control sensor is located on the left side of the top link mount. You may want to check for damage wires, plug and etc before throwing a sensor at it:
/ Red light flashes
Looks like my wire wise is in great shape. I did locate draft sensor unplugged wires and reinstalled. No sign of damage or problem with wires or sensor. If I replace sensor will I need to reset computer to get rid of code and flashing light? Unhook battery or pull a fuse maybe? Thanks
Harlo HP6500 (A60462)
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
Hydraulic Breaker Excavator Attachment (A61572)
Hydraulic Breaker...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
2023 CATERPILLAR 320 EXCAVATOR (A62129)
2023 CATERPILLAR...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
