red hot muffler on LT1045
   / red hot muffler on LT1045 #1
lil_country
Bronze Member
Central Oklahoma
2006 B3030 & 2006 Cub Cadet LT1045
I just bought a used LT1045. Today my wife mowed with it for the first time. She had been mowing about 30 minutes when I noticed that sparks were coming from the muffler. I had her stop, and on closer inspection I could see that the muffler was bright red. It was so hot that the front tires were hot. Any help diagonsing the problem would be appreciated.
   / red hot muffler on LT1045 #3
What engine is in this LT1045?
Kohler Courage 20
   / red hot muffler on LT1045 #5
Is it a few years old? I'm wondering if something is loose around the intake or cyl head letting air in and leaning out the air/fuel ratio? Some early Courage singles had issues with bolts loosening up.
It is a 2006 model, but has very low hours. It is also a 2 cylinder model. I'll try adjusting the mixture and see if it helps.
   / red hot muffler on LT1045 #7
Also be sure there are no mouse nests under the shroud, assuming this is air cooled.
   / red hot muffler on LT1045 #8
Good call there. I haven't heard of a single issue with the Courage V-twins. I owned a 20 and loved it.
If there was a nest, there would have been flames. That muffler was about to melt down.
I've adjusted the fuel mixture. We will see if that helps. Thanks for the response.
NEW Fork Extensions (A53002)
NEW Fork...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2009 CHEVROLET SILVERADO (A52472)
2009 CHEVROLET...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2021 John Deere RD40F Draper Head (A53342)
2021 John Deere...
