Price Check Red Guy on a Blue Page - Tractor for Sale
   / Red Guy on a Blue Page - Tractor for Sale #1
MarEng
Willis, TX
Branson 3510 Ford 3000
Our subdivison is interested in selling the association tractor. It is a Ford with nameplate data as follows:
Tractor #: C688692
Model #: BS3530
Unit #: 2F04B
Engine #: 2D28A (Gasoline)
Transmission: 2D29B
Hydraulic Pump: 2D5B
Rear Axle: 2D29B
Hydraulic Lift: 2D23B
It has a hydraulic top link and a hydraulic tilt. It also has a third rear remote. From past memory - the brakes are marginal but the engine seems strong. I think everything else works but we can't find the key so I haven't been able to test it yet.
Any ideas as to year of manufacture? Any ideas as to value? We'll probably put it on e-Bay to avoid claims of nepotism. Any suggestions are appreciated.
   / Red Guy on a Blue Page - Tractor for Sale #2
I am not sure about value.... but a pictures would help
Working on pics - they're stuck in the camera as we look for the cable . . . if it ain't one thing it's another.
   / Red Guy on a Blue Page - Tractor for Sale #4
does the camera not have a removeable memory card?
as for needing the keys.. :) that's nothing a 6" piece of wire with gator clips won't solve...
as for model. it's newer than I have number listings for ( handy anyway..).. sounds almost like some sort of 26XX model though..
awaiting pics..
soundguy
   / Red Guy on a Blue Page - Tractor for Sale #5
I think it may be a 1982 2910 since they were made with both gasoline and diesel 3-cyl engines (40+ hp). A photo would sure help. The three remotes and TnT on the 3PH really means somebody was willing to spend some money on making improvements. I don't think you will find that on may tractors of that vintage. Lookin' forward to photos. . . .
   / Red Guy on a Blue Page - Tractor for Sale #6
yep.. 3 remotes is a chunk of change.
soundguy
Pics attached - new it isn't. The subdivision had private gravel roads when built in the 60s and the tractor was used to maintain them. The rear remotes were used to manage a Series 785A Blade (that will also be sold). The county took over the roads and paved them in the 80's. Thanks for the help.
   / Red Guy on a Blue Page - Tractor for Sale #8
has to be a 2600/3600 or later.
man. .i bet them remotes are worth about a grand right now.. :)
soundguy
   / Red Guy on a Blue Page - Tractor for Sale #9
Cosmetic it's not, but it looks like it is all there so the potential is there for a nice usable tractor.
When was it last running? The oil filter has a lot of surface rust on it so I doubt it has been changed in awhile.
The sheet metal (I didn't open all of the photos-I have dial up) from what I saw looks good however the fiberglass nose cone needs some serious work or replacement.
Too bad your community won't sell it through a sealed bid process via a couple of ads in the local papers. If that were the case and if in fact it was demonstrated as running with all systems operational I would write down $2001.00 and lick the envelope!:thumbsup:
When the time comes, do let us know what it sells for.
   / Red Guy on a Blue Page - Tractor for Sale #10
i think the fibreglass top piece is likrly fine.. the lower nose clip either will need lotsa work, or replacement.
i know on the early series(2000/3000 ), it's 1-piece metal and about 500$ :) hopefully the units with the flip top f/g you can ge tthe lower and the grill seperate.
soundguy
REIST R25PSS LOT NUMBER 231 (A53084)
REIST R25PSS LOT...
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
John Deere S780 Combine (A53342)
John Deere S780...
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
198367 (A51243)
198367 (A51243)
Kawasaki NR (A50324)
