Recommended Tractor for 4.5 acres
/ Recommended Tractor for 4.5 acres #61
Hello! I’m under contract on a house with about 4.5 acres (1.1 ac wooded) and would like some opinions.
Most of the property is grassland, so mowing would be the most frequent usage. It has a 300’ dirt driveway and the property needs some grading and dirt work near the foundation, so I’d like a box blade. After the initial grading, the box blade usage will be seasonal for driveway maintenance.
The current owner is using a zero turn mower, but about an acre of the property is severely overgrown. I’d prefer a fail mower to a brush hog for maneuverability.
It also has a hobby farm set up that we’ll continue to use, so the loader will be handy.
It’s in Kansas, so some snow, but not in huge quantities… usually.
I was originally looking at the Kubota BX2380 and Deere 1025R. I’m leaning to Kubota, but it looks like I can get a B2301 for only $1000 more.
This will be my first tractor, but I often used my dad’s Deere 4310 when I was in high school on about the same amount of land. He lives in a state with a lot of snow, so it’s mostly used as a plow.
Are there any other contenders I should look at? And is the B01 worth the price jump over the BX?
Thanks!
I would look at a Mahindra 3600 series..they come in shuttle or HST drive, 36HP especially if you are looking for a FEL, the HST is optimal for mowing and dirt work...the Mahindra will be cheaper also, born of Internationals and modernized some to be a value branded tractor. I just purchased a 4540 and it seems to be a havy built machine, made to work.
/ Recommended Tractor for 4.5 acres #62
For my 2 cents:
For me, having a dealer close by is top of the list. Like fire insurance, you hope that you never need it, but when you do, you want help close by. When I was looking for a used tractor, the closest dealers were Kubota, JD, and NH.
As for parts, many parts today are as close as your phone or Internet store, so that is not always as important. Also, that allows some price shopping as well.
If you can, find someone near by with a like or similar tractor to what you think you want. Try it out. Or better yet, find a dealer that will let you test a model. On occasion, you will find one that has a 'used model' that they will 'rent' out for a day or so and let you get the feel.
Make a list of all the features that you 'must' have and another side list of "nice" to have's. Once you have a list of tractors that meet those needs, then do comparative price shopping.
/ Recommended Tractor for 4.5 acres #63
Seriously, 4.5 acres in Kansas (mostly flat I assume) any of the sub compacts will do what you need within reason. The little tractors like the BX are quite capable but you have smaller loader and lift, less side to side stability and less weight. They will do a ton work once you learn their limit and don't pretend it is big tractor. I have 4500 hours on mine and moves dirt and rocks all the time. It small nimble and fits into 4 foot spaces. I like the belly mower for areas my Z turns don't like or when I want gather up some bedding for the rabbits. I will mow serious slopes and knee high grass with few complaints. The 3 point will handle anything for it's class but sometimes I've had to fix implement to get them low enough for the short BX.
The next size up (B series, etc) increases hydraulic power, weight and stability. Will handle some bigger tools and you might see over the weeds instead of into them as you brush hog. It will not be as nimble nor will it go through a 4 foot gate but will gain a ground clearance and bigger tires. The little BX tires and short wheel base will beat you on rough ground and it worse with loader full. The bigger loader will move more and lift heavier things. Don't know about a belly mower but it will sure pull any type of 3 point mower you want (in the right sizes of course).
I was assuming Kansas = "flat" too, but if it's hilly a B might be more ideal, as you mentioned. I have a BX1880 in Kentucky and I'm on a pretty steep hillside a lot. I'm careful and have developed my tip-o-meter (aka my posterior), and it's working out fine, but the wider stance of the B would be a + in hilly conditions.
/ Recommended Tractor for 4.5 acres #64
I've had an LS 33 HP 4WD for over 10 years. I have a box blade, loader, brush hog and front and rear hay spears. (I use the front ones for a whole lot of things besides hay). The LS is normally 7-8 thousand cheaper than the premier brands, and I have had very few problems with it.
/ Recommended Tractor for 4.5 acres #65
With respect to the FEL/box blade discussion, I would emphasize that it's not "either" an FEL "or" a box blade - having both would be nice (i don't have a bb yet), and also lots of people use the box blade for ballast weight when the FEL is on the tractor. I have a Heavy Hitch/suitecase weights for my BX, but in retrospect a box blade might've been a more efficient use of $.
/ Recommended Tractor for 4.5 acres #66
Thanks!
If you can afford it, still get a ZTR for most of your mowing. I used to have a Kubota B7100 HST with a 60" mower. It took me about 3-3.5 hours to mow 5 acres, and then I still had to trim up with a push mower and a weedwhacker, as a tractor cannot get into tight places. My Bad Boy ZTR mows the whole thing in 90 minutes, and I do not need to trim with a push mower. If you also get a tractor, get a loader and a small bush hog. I used to use a 4' model with the Kubota. I would also suggest considering Mahindra for small tractors.
/ Recommended Tractor for 4.5 acres #67
Don't limit yourself to orange and green. Red (Massey, Mahindra, TYM and Branson) and blue (LS and New Holland) are every bit as capable and usually cost quite a bit less.
Limit yourself to whatever color has a good cheerful and cooperative dealer near by. YOU WILL have continuing needs to work with a dealer be it questions, parts, upgrades, repairs -- dealers are very nearly more important than whatever brand they sell. Ask around. See what the farmers (even weekend farmers) say about the local dealers. Valuable.
/ Recommended Tractor for 4.5 acres #68
Weight = work for ground engaging tasks. The lighter the machine, the harder it is to get an implement into the ground or move things.
I would not go smaller than a Kubota B series (or JD 2 series) or equivalent. I am also not a fan of flail mowers...300 moving parts vs 50 on a rotary cutter. Just more to break. Personal preference here.
How much dirt needs to be moved?
Agree on the mower. You mention a pretty rough section of growth. Flail mowers are more expensive and easier to damage even in relatively minor brush and debris than a rotary mower. I have used 4', 5' brush hogs on the compact size tractors and I'd lean to a 5ft in your case on a roughly 26-30hp tractor. Don't even think about a 2WD. 4WD is essential.
/ Recommended Tractor for 4.5 acres #69
i hear you, get comfortable with the dealer first, but IMO if i was comfortable with the dealer and had the ability to haul the tractor, 90 miles if it is good roads is not that much more trouble than a 25 mile drive considering the work involved in connecting the trailer loading and securing the tractor and then have to leave it at the dealer for 3 days before they can look at it etc.
LS has a great lineup and very attractive pricing right now and that is comming from someone who just bought and loves a Mahindra.
There is no way in H I would go with an LS tractor in lieu of other good brands when the LS dealer is 90 miles away.
/ Recommended Tractor for 4.5 acres #70
Hi Diggin it,
I currently own a 5045E and are looking to purchase a smaller size tractor (25HP) for cutting the grass mostly lol (joking but not really) I’ve been looking around at a lot of different brands including JD, Mahindra Kubota and Kioti and I’m just not seeing much difference in price. I’m leaning towards and 2025R Bc the increased weight and ground clearance over the 1025 which should only run you about 2500 more for the 2025R
However the JD 2025R does not allow you to operate the mid mountain mower independently unless you buy a conversion kit. If you go to the next size up the 2032 I believe you’ve got the command cut standard but you’re looking at it a price jump of 6K.
My advice is don’t make the fatal error of buying too small of a tractor take advantage of the 0% interest for 60 months and go ahead and get ya at 5045 and have them set the wheels out this is a very safe you can dig with the loader it’ll be a a tractor for you for a long time.
If you’re stuck on the price point of under 25 I’m gonna say look really hard at the kioti cs 2520 I found an advertised deal of $13,700 base +
Add Attachments-
SL2420SSOA Loader- $2,599
SM20 Series Mower in 54" or 60"- $2,099
SB2420 Backhoe with your choice of bucket
$5.799
That’s a little over 24k for a front loader, 60 MMBM, and backhoe. Unfortunately I’ve seen quotes from different dealers on the same tractor for 5K more
The local Mahindra dealer wants 30 K for the same set up and that’s what I was quoted for a JD2025.
I definitely would not go with a rural King tractor they use different manufacturers about every five years and parts can be difficult to come by, just my opinion of course.
/ Recommended Tractor for 4.5 acres #71
Bought a new MF1739E April 2020 when we purchased our retirement property in central Mo. The size has been very good for our needs of 53 acres, 40+ timbered. The FEL loader is always used. I currently have a box blade that remains on it for counter weight. We are always taking trees away from near the home so the 1600lb FEL capacity is good. Never used the pto so can't comment. Now that said l do want to purchase implements to use but not with this tractor. It'll be traded in or sold for a larger, either MF 4707 or Cat skid steer. I'm looking at getting a mill and need a machine with lifting weight for long logs. As mentioned here about sizing for your job. You could go smaller tractor and get a zero turn. l did this. Purchased a 61" Scag for 5k also April 2020. You need to figure time it'll take you to accomplish tasks with your purchase choices. Tractor & rotary cutter. Tractor and zero turn, ect. Best of luck on your decision. Now to start looking myself...
/ Recommended Tractor for 4.5 acres #72
Thanks for the replies. And sorry for the confusion, but I’ll be getting the loader for either. It looks like the B2301 FEL has about 200 pounds of lifting capacity over the BX2380 (948 vs. 739).
The attachments I’d be looking to buy at the jump are the loader, belly mower, box blade, and maybe a brush hog or flail mower.
Is a loader easier to use than a box blade for creating a slope away from a foundation?
Don't know if it was noted elsewhere in this discussion, but are you not going with a backhoe model? Plusses/minuses, like everything else, but if the BH is out, a "plus" is that it leaves more room within your budget for the brush hog, flail, etc. For example I think the Kubota BH models are around 25k these days (someone will correct me if that's inaccurate).
Also....congrats on your new property - sounds terrific!
/ Recommended Tractor for 4.5 acres #73
On paper, I’m really intrigued by the Yanmar SA424 & SA324, New Holland Workmaster 25S, and the Kubota B2601HSD.
There are two good Kubota dealers near me, but the NH/Yanmar dealer is a bit of a hike. I like the Deere, but the 2-series is considerably more expensive for the capabilities compared to the others.
I recently bought a new compact tractor. I looked at the specs and pricing for Kubota, Deere, Yanmar and a few others. I decided on the Yanmar SA424. It really has exceptional lift capacity for the 3pt and the loader for its size (both 1200). I also like the hydrostatic transmission with the dual pedal. I also decided to get the mid-mount mower and sold my 3pt finish mower.
/ Recommended Tractor for 4.5 acres #74
You got me researching this LS tractor price point six-year power train warranty and right now they’re offering three loader according to the website. Until now I was going back-and-forth between the JD 2025R and a Kioti CS 2025. Tractors are crazy expensive right now!
/ Recommended Tractor for 4.5 acres #75
Take a real good look at the MT225S, maybe check them out on TractorHouse and get a feel for them.
/ Recommended Tractor for 4.5 acres #76
Sounds like we are both researching the same thing (25 hp tractor with the midmounded mower and backup capability )you went ahead and pulled the trigger on the Yanmar.
Can you elaborate a little bit more on why you went with the yanmar , your experience with it so far (good and bad)and how much it ultimately paid?
/ Recommended Tractor for 4.5 acres #77
Id make an offer in the current ZT from the owner if its a decent one in good shape. Use that for cutting grass. Get a tractor for tractoring including brush hogging your overgrown in the spring or late fall. Flail mower is $$ not sure you need it.
for 1 acre overgrown pay a neighbor to brush hog it for you. Then cut with ZT.
Belly mowers are a pita to take off put on until you get used to it. I'd rather pull a rotary cutter and ZT cut everything else but I doubt you'd need a rotary cutter for much work. With a garden I'd get a decent tiller skip the rotary cutter and flail mowers. With more land yeah but 4 acres....
Make friends with your farmer neighbors for that 1 time you need a flail/rotary.
The tractor is significantly heavier than a ZT so in the spring when you first cut the tractor will make ruts and you wont notice until the summer and you're bouncing all over the place cutting grass. Why you see folks rolling grass with a roller in spring. That challenge is real. bumpy ride cutting grass is back breaking work after a few minutes.
Get the biggest tractor you can afford with a FEL. I wouldn't buy a tractor for finish mowing, thats what your ZT is great at.
/ Recommended Tractor for 4.5 acres #78
the 3600 series is not available any longer per my dealer.
5100 is heavier and cheaper with better fel lift, but no HST
/ Recommended Tractor for 4.5 acres #79
Thanks!
A great tractor for you would be a Kubota B3200. Newer but no emissions crap to worry about. Decent attachments. Get front mount for snowblower, Mid mount mower, and enough power for your chores. Small enough for the mowing with a 60 inch deck. You can do box blade, tiller and other stuff with the 32hp giving you around 27pto hp.
/ Recommended Tractor for 4.5 acres #80
In some areas of the country that is not too far.
My dealer will pickup and deliver at no charge for any reason within about 125 miles IIRC. It was one reason, of many, why I went with LS but not all LS dealers will do that. The Kutoba dealer was closer (45 miles) and he quoted $300 per round trip. The JD dealer was 25 miles away and quoted $150.
Plus, I saved over $8000. You could be correct for your case but not for someone like me. Not needing to purchase a trailer, and saving $8000 was more important than getting my tractor a day or so sooner if it needed work. But I am a hobby user so a day or two is not critical.
BTW, the one time I had to have it serviced for an oil leak, I called before noon and had it returned midafternoon the next day. Another time I needed a fitting for the third function valve and he took the fitting out of a stock valve and gave it to me at no charge. He is about 55 miles away. I would buy from a dealer like that if he was 125 miles away.
Not all dealers are created equal. For any of you living in northern MI, check out Sumerix. Ask for Ivan, and tell him I sent you....
Don from Johannesburg
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
2018 Nissan Pathfinder SUV (A64557)
2018 Nissan...
Landhonor 3-Pt PTO Potato Harvester (A66285)
Landhonor 3-Pt PTO...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
215603 (A63276)
215603 (A63276)
NEW Wolverine 66" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 66"...
